Editing a Filter Definition
You can easily edit a filter to change its name or expression.
  1. Select Filters on the Table Design Ribbon.  The Filters window displays.
  2. Select a filter on the Filters selector. Depending on the type of filter you have selected, one of the following windows displays:
  3. Edit the filter's properties as needed.
