The Analyze Drop-Down
The Analyze drop-down displays when you click the Analyze tab in the Data Prep Studio toolbar.
The Analyze drop-down is your take-off point for creating, viewing, modifying and managing summaries.
Options
Option
Summary
This drop-down allows you to select from multiple summaries which summary to display on-screen
Active Measure
This drop-down allows you to select from multiple measures which measure to apply to the summary
Add Summary
This button allows you to create new summaries via the Add Summary dialog
Edit Summary
This button allows you to modify summary definitions via the Edit Summary dialog
Manage Summaries
This button allows you to manage summaries via the Manage Summaries dialog
Drill Level
These buttons show how many drill levels there are in the selected summary and allow you to drill up or down as desired.
Filter
This drop-down allows you to select from multiple filters which filter to apply to the summary
Add Filter
This button allows you to create new filters (i.e., formula, value, and compound filters) via the Edit Filter dialog
Edit Filter
This button allows you to modify filter definitions via the Edit Filter dialog
Manage Filters
This button allows you to manage filters via the Manage Filters dialog
Sort
This drop-down allows you to select from multiple sorts which sort order to apply to the summary
Add Sort
This button allows you to create new sort orders via the Edit Sort dialog
Edit Sort
This button allows you to modify sort order definitions via the Edit Sort dialog
Manage Sorts
This button allows you to manage sort orders via the Manage Sorts dialog
© 2024 Altair Engineering Inc. All Rights Reserved.
