Grouping Columns
Group allows you to classify or consolidate rows that belong together according to some common value within the row. When you consolidate the records, you can also select column values to aggregate.
For example, records like these, that show Customers and Items and Quantities:
Can be grouped by Customer and Item, to find out the total item quantities bought by each customer:
Note that You can only group columns from the Prepare Window.
  1. In the Prepare window, select the table you want to group.
  2. Select Transform on the Data Prep Studio Toolbar.
A dialog box allows you to select a transformation.
  1. Select Group By to display the Group By dialog:
  1. Set Grouping options:
  • Enter the name of the resulting table
  • Click the Case Sensitive box if you want to differentiate values based on case. For instance, CD and cd are considered two distinct values if case sensitivity is on, and will result in two groups for this value.
  1. Select the columns to group on by selecting the Key  icon beside a column on the Value Columns section of the dialog box:
In the example above, we are selecting Media as a group by column. Once selected the column is moved to the Group Columns section.
  1. Select the columns to include in the transform.
To select the specific columns to use as values, check the box beside a column.
To select all columns check the box on the header row. Note that this check box is disabled if you are selecting columns via a column search (essentially filtering columns).
  1. If applicable, select the aggregate operation to use.
To do so,  select the operation from the drop-down beside a value column you have selected to include  in the grouping:
In the example above, we are including Qty in the grouping and have selected Sum as an aggregation.
Notes:
    • Data Prep Studio uses a default name for the aggregation. You can change this using the New column name column.
    • Different operations are available for specific data types:
Operation
Valid for
Sum
number
Computes the sum of all item values in the group.
Example:
TOTAL AMOUNT
VALUE
Amount 1
10,000.00
Amount 2
20,000.00
Amount 3
30,000.00
Amount 4
40,000.00
Amount 5
50,000.00
Sum (Total Amount)  = 150,000.00
Average
number
Computes the  average (sum of all item values divided by the number of items)  of all the values in the group.
Example:
TOTAL AMOUNT
VALUE
Amount 1
10,000.00
Amount 2
20,000.00
Amount 3
30,000.00
Amount 4
40,000.00
Amount 5
50,000.00
Average (Total Amount)  = 150,000.00 /5 = 30,000
CountNotEmpty
number
Counts the number of non-empty items in the group:
Example:
TOTAL AMOUNT
VALUE
Amount 1
10,000.00
Amount 2
Amount 3
30,000.00
Amount 4
Amount 5
50,000.00
CountNotEmpty (Total Amount)  = 50,000.00
Maximum
number, date
For numeric columns, returns the maximum value among all item values in the  group.
Example:
TOTAL AMOUNT
VALUE
Amount 1
10,000.00
Amount 2
20,000.00
Amount 3
30,000.00
Amount 4
40,000.00
Amount 5
50,000.00
Maximum (Total Amount)  = 50,000.00
For date columns, returns the latest date.
Median
number
Returns  the median value among all item values in the  group.
Example:
TOTAL AMOUNT
VALUE
Amount 1
10,000.00
Amount 2
20,000.00
Amount 3
30,000.00
Amount 4
40,000.00
Amount 5
50,000.00
Median (Total Amount)  = 30,000.00
Minimum
number, date
Returns  the minimum  value among all item values in the  group.
Example:
TOTAL AMOUNT
VALUE
Amount 1
10,000.00
Amount 2
20,000.00
Amount 3
30,000.00
Amount 4
40,000.00
Amount 5
50,000.00
Minimum (Total Amount)  = 10,000.00
For date columns, returns the earliest date.
Count
number, date, text
Counts the number of items in the group.
Example:
TOTAL AMOUNT
VALUE
Amount 1
10,000.00
Amount 2
20,000.00
Amount 3
30,000.00
Amount 4
40,000.00
Amount 5
50,000.00
Count (Total Amount)  = 5
First
number, date, text
Displays the first value on the table.
Example:
TOTAL AMOUNT
VALUE
Amount 1
40,000.00
Amount 2
20,000.00
Amount 3
30,000.00
Amount 4
40,000.00
Amount 5
50,000.00
First (Total Amount)  = 40,000.00
Last
number, date, text
Displays the last value on the table.
Example:
TOTAL AMOUNT
VALUE
Amount 1
40,000.00
Amount 2
20,000.00
Amount 3
30,000.00
Amount 4
40,000.00
Amount 5
10,000.00
Last (Total Amount)  = 10,000.00
  1.
  2. Select OK.
Data Prep Studio applies the grouping and  creates a new table.
© 2025 Altair Engineering Inc. All Rights Reserved.
