Connector Dialog for SharePoint
Notes
- This connector requires a Java Virtual Machine (JVM) to function properly.
- As an alternative to using just the Sharepoint Connector dialog, you can also use ODBC DSN and the Altair Sharepoint Driver to connect to a Sharepoint data source. Refer to Using ODBC DSN if you want to connect using this method.
Using Standard Connector Dialog
The Sharepoint Connector dialog includes the following fields and settings:
Field |
Description |
Connection |
Service URL |
Enter the endpoint for the Microsoft SharePoint service to which you are connecting. |
Authentication Method |
Determines the authentication method to be used during the course of the session. Select the method from the drop-down list. |
Client ID |
Enter the client ID key for your application when authenticating to REST endpoints with OAuth 2.0 enabled |
Client Secret |
Enter the client secret for your application when authenticating to REST endpoints with OAuth 2.0 enabled. Important: The client secret is a confidential value used to authenticate the application to the service. To prevent unauthorized access, this value must be securely maintained. |
Access Token |
Enter the access token used to authenticate to REST endpoints with OAuth 2.0 enabled. Typically, this option is configured by the application; however, in some scenarios, you may need to secure a token using external processes. In those instances, you can also use this option to set the access token manually. Note: You can use the Copy/Paste icon |
Refresh Token |
Enter the refresh token used to either request a new access token or renew an expired access token for OAuth 2.0 implementations. Important: The refresh token is a confidential value used to authenticate to the service. To prevent unauthorized access, this value must be securely maintained. Note: You can use the Copy/Paste icon |
Authorization URI |
Enter the endpoint for obtaining an authorization code from a third-party authorization service for OAuth 2.0 implementations. |
Token URI |
Enter the endpoint for retrieving access tokens when OAuth 2.0 authentication is enabled. |
Scope |
Enter a space-separated list of OAuth scopes that limit the permissions granted by the access token. |
Redirect URI |
Enter the endpoint to which the client is returned after authenticating with a third-party service when OAuth 2.0 authentication is enabled For some authentication flows, the REST service will redirect you to a third-party service for authentication. Once your credentials have been validated, the third-party service returns the client to an endpoint in the REST service to continue the session. The endpoint used by the third-party service is provided by the client and specified using the Redirect URI option. |
Reset Connection |
Check this box to reset the OAuath connection and fetch new access tokens. |
TEST CONNECTION |
Click to initiate a connection and test the values you have entered. If there are errors, messages will be displayed beside this button. Notes:
Tables & Views |
Tables & Views |
Allows you to load, and then select, the tables from your database by manually selecting from a list.
To load tables and views via search and select:
Note: If you wish to add a duplicate column, select this column from the Add a duplicate column drop-down list provided.
To select a column: Check the boxes beside the columns you want to use. If you want to use all columns, check the Column box on the header.
To aggregate columns: If the data returned are to be aggregated, check the Aggregate box on the header, then select the aggregation method you want to use for each column.
The following aggregation methods are possible for each data type:
To filter columns: If the data returned are to be filtered, check the Apply Filter on the header. Then, for each column, select a filter method from the filter drop down and then enter the filter value in the Filter Value box.
Notes:
Preview Data |
Click to fetch data using the credentials and criteria you have specified. This allows you to confirm your connection, ensure you have connected to the correct table, check your query, and verify the information that will be loaded. Notes:
Query |
Query |
Allows you to load, and then select, the tables from your database by entering a SQL Statement. If you already selected Tables and Views, this box is updated to show the corresponding SELECT * FROM TABLE query.
If you want to define the query, enter the SELECT, EXEC, and/or WITH statements to execute.
Notes:
Preview Data |
OK/CANCEL |
Select OK to establish the connection and fetch data or Cancel to close the dialog. The state of the OK and PREVIEW buttons provides a handy status about the state of your connection:
Notes:
Optional Fields. Other fields are optional but you may need to consult your data source administrator for other field values you need to enter to connect.
Connection Strings that Exceed 1020 characters. For Connection Strings that exceed 1020 characters, a File DSN is temporarily created. Refer to this page for details on the implementation.
Support for Short Names: Progress short names are supported by this release of Data Prep Studio, specifically in the Other Connection Options field. Refer to this page for details on the implementation.
If you encounter a Test Connection or connection error, try connecting via ODBC DSN instead.
Using ODBC DSN
To use ODBC, you need to define the ODBC DSN and then call it using the Sharepoint Connector dialog.
Create a valid ODBC DSN SharePoint Connection. Add a System DSN and select the Altair SharePoint driver. You will be asked to populate the Progress DataDirect: Create Microsoft Sharepoint Data Source Configuration dialog.
In DPS, use the Sharepoint Dialog (as above), but:
Use dummy data to populate required fields. (This step will allow you to bypass basic validation.)
In the Other Connection Options field, indicate the ODBC DSN you created in Step 1.
Use the form DSN=<DSN Name>, for example: DSN=MySharepont.
Also note: Other Connection Options is the last field on the dialog, so you need to scroll all the way down to populate this field.
Click Test Connection. This should return a successful connection
Click Load Tables. This will return tables available.
Click Preview Table.
Click OK to load the connection.
Notes:
ODBC DSN will only work for Altair SharePoint Driver.
Define all driver connection properties in the Progress DataDirect: Create Microsoft Sharepoint Data Source Configuration dialog.
When a DSN is indicated in Other Connection Options, all other fields in the Sharepoint Connector dialog are ignored.
