Connectors with Case-Sensitive Filter Values
In most connector dialogs, you have the option to apply filters to limit the data that will be loaded into Data Prep Studio.
To do so, locate the column list on the dialog and check the Apply Filter on the header:
Then, for each column, select a filter method from the filter drop down and then enter the filter value in the Filter Value box.
Some data sources require case-sensitive filter values. Refer to the list below to check which data sources have case-sensitive filters.
Connector
Case Sensitive
Active Directory
no
Amazon EMR Hive
yes
Amazon Redshift
yes
Business Objects
no
Cassandra
yes
Cloudera Data Platform (formerly Cloudera CDH Hive)
yes
Cloudera Impala
yes
DB2
yes
Google BigQuery
yes
Hadoop Hive
yes
Hortonworks
yes
Hubspot
yes
Informix
yes
HPE Ezmeral Data Fabric (formerly MapR Hive)
yes
MySQL
no
NetSuite
no
Odata
no
OLEDB
no
Oracle
yes
PostgreSQL
yes
ServiceNow
yes
SharePoint
no
Snowflake
yes
Spark SQL
yes
SQL Azure
no
SQL Server
no
Sybase IQ
no
Teradata
yes
Vertica
yes
Note: Information on case sensitivity is based on test results, but these results can vary depending on the data source configuration.
© 2025 Altair Engineering Inc. All Rights Reserved.
