Create a Section Cut
Create and view 2D section planes of your model.
                In the view controls, click the Section Cut
 tool.
                A transparent section plane preview appears. - Click the section plane preview or elsewhere on the model to create the section cut.
                Drag the section plane to reposition it, or use the microdialog options to
                    move, align, or flip the section plane.
Tip: To show section cuts in the part color, right-click the section plane and select Show Section Cuts in Part Color. -
                Click
 to
                    create additional section planes.
Tip: To a hide a section plane, select it and press
                H, or click its icon in the Model Browser. You can show all
                section planes using the right-click (context) menu.
            Tip: To align the model so the
                section cut is aligned with the current view, right-click the section plane in the
                Model Browser and select Align Normal to View.
Microdialog Options
| Option | Description |
| Section Plane Only |
                            By default, one side of the model is hidden. Click to hide both sides of the model and show only the section plane. |
| Flip Section Cut |
                            Reverse which side of the model is hidden. |
Move Section Cut Plane![]()  |
                            Translate or rotate the section plane using the Move tool. |
| Align to Global X, Y, Z Axis |
                            Align the section plane to the x-, y-, or z-axis. |
| Reposition section plane to model
                                    center |
                            Reposition the section plane to the model center. |
Keyboard Shortcuts & Mouse Controls
| To | Do this |
| Hide a selected section cut | H |
| Add to or remove from the selection | Ctrl |
| Exit the tool | Esc or right-click |
