Delete
Delete objects using the keyboard or context menu.
Choose from the following options:
- Select the objects, and then press Delete.
- Right-click the selected objects, and then click Delete on the context menu.
Type of Object Deleted | Result | Note |
Part | All the loads, supports, and shape controls attached to that part are deleted. | |
Assembly | All the parts and subassemblies in the assembly are deleted recursively. | |
Load Case | The loads and displacements in that load case aren't deleted. | Load cases refer to objects but do not actually contain them. |
Load, Support, Displacement Constraint | The entity is deleted from the model and consequently all load cases. | To delete an entity from a load case without deleting it from the model, right-click the entity, and then click Exclude from. |
