Translate Objects
Translate objects along an axis or line, within a plane, or in 3D space.
Translate Objects along the X-, Y-, and Z-Axes
Translate objects along the x-, y-, and z-axes with the ability to use variables.
Select the Move tool, or press
T
or M.
- In the guide panel, select the Translate tab.
- Next to Part, the Select button is active. Select one or more objects.
- From the Direction dropdown, select Components.
- To define the translation distance, enter values, the drag the sliders, or assign variables for Translate X, Translate Y, and Translate Z.
Tip: When you move parts, they are allowed to pass
through each other by default. To prevent this, turn on collision detection in the
Preferences window.
Translate Objects along a Line
Translate objects along a reference line with the ability to use a variable.
T or M.
- From the Direction dropdown, select Along line.
Next to Line, the Select button
is active. Select a line, axis, or cylinder.
Note: When a cylinder is selected, objects move along the center line of the cylinder.
Define the translation distance:
- Enter a Magnitude, drag the slider, or assign a variable.
- Drag the manipulator.
Preferences window.
