2026.1
Get started with Inspire Extrude Metal.
Evaluate designs by using geometric variables and applying a design-of-experiments (DOE) or optimization method. We recommend fully constraining your sketch when sketch variables are used in the design exploration.
Goals comprise objectives and constraints.
Discover new features and enhancements in Inspire Extrude.
New to Inspire Extrude? Learn the basics here.
Inspire Extrude Metal offers an analysis tool for virtual testing, validation, correction and optimization of extrusion die designs.
Find answers to Frequently Asked Questions from our users.
Setup and perform an Extrusion analysis.
Setup and perform a Tool Deflection analysis.
The Design Explorer Browser displays a hierarchical view of your design setup and can be used to enable and disable exploration parameters.
An exploration is a DOE or optimization simulation. Each exploration must include design variables and responses. Optimizations must also include an objective and optionally constraints.
Design variables are changes of the geometric variables that influence the performance of certain analyses.
An output response is a measurement of system performances, such as mass, volume, displacement, or stress.
Objectives are metrics to be minimized or maximized in an optimization exploration. Common examples are minimizing displacement to find the stiffest design for a system or minimizing mass to find a lightweight design.
Constraints can be added to an optimization and need to be satisfied for a feasible exploration.
Use the Evaluate tools to run the exploration and review reports.
Setup and perform a quenching analysis.
Find information about material data blocks in GRF files.
Start using Inspire Extrude with our interactive tutorials.
Get started with Inspire Extrude Polymer.
Get started with Inspire Friction Stir Welding.
Get started with Inspire Resin Transfer Molding.
Create 2D sketches, surfaces, and solids.
