/VEL/ROT
Engine Keyword Given node numbers have the same rotational velocity in a specified direction X, Y or Z.
/VEL/ROT/Keyword3/skew_ID
N1 N2 ... NN
Definition
| Keyword3 | A combination of
X, Y, and
Z: X, Y, Z, XY, XZ, YZ, YX, ZX, ZY, XYZ, YXZ, ... |
| skew_ID | Skew identifier
(optional). If omitted, the equation is written in the global skew system; otherwise it is applied in the given skew_ID. |
| N1 N2 ... NN | List of node numbers having the same velocity. |
- Given node numbers have the same
rotational velocity in a specified direction X, Y or Z:
