/SUBDOMAIN
Multi-Domain Keyword Defines the parts belonging to the subdomain of a Multi-Domain computation.
/SUBDOMAIN/subdomain_ID
subdomain_title
Part1 Part2 Part3 Part4 Part5 Part6 Part7 Part8 Part9 Part10
Definition
subdomain_ID Subdomain identifier
(Integer, maximum 10 digits)
subdomain_title Subdomain title.
Part1, Part2, ... Partn List of parts
(Integer)
  1. Currently only one domain can be defined.
  2. The subdomain title is used as the rootname for the new Radioss model created for the subdomain.
  3. These options are not compatible with /SUBDOMAIN:
    • /DFS/DETPOINT/NODE
    • /FX_BODY
    • /SPHBCS
  4. For more information concerning Multi-Domains, refer to Multi-Domain Technique.
