Solid Elements Examples An elastic material law is defined for solid elements. Input user data includes density, Young’s modulus, and Poisson ratio. Figure 1. Solid Elements Model Example Demo File Before you begin, copy the file(s) used in this problem to your working directory. 2_material_law_29_30_31.zip 3_extended_material_laws.zip
