This Starter output warning occurs in contact interfaces that use the constant gap
formulation, Igap=1000 and Gapmin
is defined such that
Where, is the minimum main element edge length.
WARNING ID : 94
** WARNING IN INTERFACE GAP
DESCRIPTION :
-- INTERFACE ID : x
-- INTERFACE TITLE : xxx
INPUT GAPmin xxx > (MINIMUM MAIN ELEMENT EDGE LENGTH) / 2
FOR SELF CONTACT, ARTIFICIAL STIFFENING CAN OCCUR IF AN ELEMENT IS COMPRESSED
TO PREVENT THIS WARNING, DEFINE GAPmin < xxx
POSSIBLE IMPACT NUMBER: xxx (<= 2 *NSN)
The Gapmin:
will be calculated, if it is not defined in the model.
This warning is important for self-impacting interfaces and can be ignored if the interface
is not self-imp-impacting. Figure 1 shows an element with edge length, , and a self-impacting interface where the . If this element is compressed more than 50%, the red node
enters the gap of the neighboring element and a self-contact is then detected which is not
physical. This leads to over-stiffening of the structure and non-physical behavior.Figure 1.
Therefore, it is recommended to define .
If , a self-contact will be detected which generates contact
forces from the beginning of the computation. Such a situation can be accepted if it is
local enough, but not if it is a frequent situation over the self-impacting interface. It is
possible to find the source of this message by using a pre-processor and selecting the
elements through size criteria.
If variable gap Igap=1
or 2 is used, then the following warning can
occur:
WARNING ID : 477
DESCRIPTION :
-- INTERFACE ID : x
MAXIMUM VARIABLE GAP xxx > (MINIMUM MAIN ELEMENT EDGE LENGTH)/2
FOR SELF CONTACTS WHERE THE VARIABLE GAP IS LARGE AND THE ELEMENT EDGE LENGTH IS SMALL
ARTIFICIAL STIFFENING CAN OCCUR DURING ELEMENT COMPRESSION
SOLUTION :
TO PREVENT THIS ISSUE, USE Igap=3 TO AUTOMATICALLY REDUCE THE GAP BASED ON ELEMENT SIZE
POSSIBLE IMPACT NUMBER: xxx (<= 1 *NSN)
This warning message is like the constant contact gap warning except in this case the
maximum variable gap for the entire contact is used in the check, . This warning is not as precise because it is very possible
that the maximum variable contact Gap is in a different location then the minimum element
length and therefore no problem exists in the model.
However as suggested in the warning message, using the variable contact gap Igap=3
will automatically reduce the contact gap in any area where the variable contact gap,
calculated as , is large as compared to the element edge length by adding the
following term to the variable gap calculation.
Where,
Length of the smaller edge of element connected to the main
Length of the smaller edge of element connected to the secondary node
Percentage of mesh size, default=0.4.
So the variable GAP calculation for Igap=3
becomes:
and the warning message will no longer be output.
Infinite domain detected.
This message can be written during the simulation in the Engine output file.
Such an error message may appear during sorting of contact interfaces when the distance
between some nodes of the model becomes infinite.
One has to look at the model behavior to understand why some node coordinates are infinite.
One common explanation is "flying" nodes after failure of elements belonging to interface
surfaces. In this case using Idel =2 in contact interfaces should fix
this problem.
Parameter Bumult.
To detect the secondary nodes and main segments which are in contact, a spatial sort is
necessary. Even if using high performance sort algorithms, a full sort at each cycle would
not be a fast enough solution. So during sorting, impacts within some security distance up
to the gap are retained.
The frequency of interface sorting, that is to say the security distance up to the GAP for
storing the candidates to the impact, relies on the parameter Bumult.
It is recommended to not change its value (which is by default 0.20), since it has been
determined in order to optimize the performances, based upon our experience.
Recommended tied contact option Spotflag.
For tied contact /INTER/TYPE2, Spotflag=27 should be used for tied contact
involving solid elements. Spotflag=28 should be used with tied contact
involving shells. Both of these tied contacts use the kinematic method, but will
automatically switch to penalty formulation if kinematic conditions are already defined on a
secondary node of the tied contact.
