OS-E: 0200 Beam Bending
A comparison study of the bending of a straight cantilever beam modeled using shell elements in OptiStruct Nonlinear transient dynamic analysis with the Radioss Explicit Solution.
Figure 1. FE Model with Boundary Conditions
Figure 2. Geometry of the Problem
Model Files
Model Description
This example has a simple cantilever beam with an end moment. The moment variation is modeled by introducing a constant imposed velocity on the free end. The moment is applied on a rigid body created at one end of the beam and on the other end all the DOF’s are blocked.
- Shell Elements
- First order Quad elements
- Property
- Value
- Young's Modulus
- 1000 MPa
- Poisson's Ratio
- 0
- Initial Density
- 0.01 g/mm3
- Reference Density
- 0.01 g/mm3
Results
Figure 3.
Figure 4. OptiStruct on the Left; Radioss on the Right
