Order Analysis - Study
After plotting the order analysis curves, perform a Partial sum or Order overlay response study.
- Study/Curves over
- Select the type of study to display. Choose between RPM or Frequency.
- RPM Range
- Indicates the available range, based on your results file.
- Type
- The type of response study.
- % to exclude
- Optional field that allows you to exclude a percentage of the orders from the order sum response.
- Select order to
- Select the orders that you want to exclude or include in the response
study.
- Click
to select the
entire list of orders. - Click
to deselect your
current selections. - Click
to exchange the
currently selected orders for the unselected orders in the in
the list. - Click
to select the
design variables of the highest sensitivity from the last Bar
plot.
- Click
- Show difference curve as
- Shows the difference between the original curve and the partial sum curves.
- Calculate Partial Sum for all responses
- Import Run
- Display Options
- Launches the Display Options dialog, which allows you to further customize the plot.
- Display
- Click Display to display the response study plot once your selections are complete.
