User Interface
Explore the user interface.
- Menu Bar
The menu bar contains pull-down menus that provide access to standard functions such as file management operations, system preferences, and help. You can also change the active product from the menu bar.
 - Pages and Windows
The main display area of the user interface is called a page. Each page can contain up to 16 windows.
 - Search
Quickly find and open the tools, panels, and browsers that are available from the ribbons, as well as create entities and solver cards.
 - Ribbons
The ribbon allows you to quickly access tools and standard functions, and is located along the top of the user interface. Click on an icon to open the related tool. Hovering over a group of icons may reveal additional tools.
 - Browsers
 - Entity Selectors
Use entity selectors to specify which type of entity you are able to select.
 - Modeling Window
The modeling window is where your model is displayed.
 - View Controls
View controls enable you to control the view and display of your model in the modeling window.
 - Status Bar
The status bar displays information pertaining to the currently loaded model, active tools, current collectors, and snap filter options.
