Post
Enhancements
- Support of vector and tensor plot during animation.
- Vector and Tensor plots can now be shown on undeformed or on deformed
shapes.
- A small/large deformation switch has been added to subcase entity.
- The Small Deformation check option has been added in the post preference page to control results query accordingly.
- A new tool has been added to show post preferences. From the Post ribbon,
select the Post Preferences tool from the Results
tool group.
Figure 3.
- Closed form complex filter calculation is now available for Von Mises Strain invariant.
- Rainbow scheme is now set as default for all plot control legends.
- Modal Percentage is now exposed as deformation mode.
- A change has been made in labeling for averaging method to Aggregation Mode.
- The former set up as average = simple is now relabeled as average then compute.
- Mode compute then average has been added.
- Aggregation based on part boundaries has been added as an option to plot
control.
Figure 4.
- An *.avi and *.gif export option has been added from animation in HyperMesh.
Known Issues
An application crash is possible when importing another model/solver deck after having imported results. This was already an issue in 2024.
Resolved Issues
- An issue has been resolved with w.r.t. csv configuration file for generation of derived load cases when both LSP and Envelope cases were defined.
- The *tablecontour API now triggers full clean up of any displayed plot control from result workflow in HyperMesh. This will avoid any display issue where plot control view mode was not cleaned and any plot based on table was not displayed.
- The marker plot now shows all available layers.
