Browsers
Enhancements
- Updated Show in Browser Behavior
- The Show in Browser context menu option now behaves differently for unnamed
                            entities:- If the entities selected on the graphics are within the defined limit, they will be sent directly to the browser without prompting the browser selector.
- If the selection exceeds the limit, the browser selector is displayed. This allows you to manage the selections.
- Keyboard Shortcut for Show
- From the white space of a browser, press the A key to
                        use the shortcut for the Show context menu option.Figure 2.
- Configurable Threshold Limit
- The Preferences dialog now has an option to change the limit for the entity
                        populations in browsers. Figure 3.
- Entity Defaults for Properties
- Entity Defaults can now be configured for Properties within the Ansys
                            interface.Figure 4.
- Section Cuts from the Browser
- From the browser, click the entity icon to activate
                        section cuts.Figure 5.
Known Issues
The following known issues will be addressed in a future release as we continuously
                improve software performance:
        - The Create menu keyword list is removed from the entity views upon loading a new model.
Resolved Issues
- Typing letters in the ID fields changed the ID to a random number.
- Deleting Solids or Connectors from the Model Browser now prompts you to delete the associated entities.
- The keyboard shortcut “R” was not working on the View entity.
- Nodal Coordinates were not updated in the Attribute columns upon moving nodes.
- Metadata added to the Feature entity was not shown in the Attribute columns.
- Sorting the Min/Max Occupied columns did not work when an empty value was present.
- Context menus did not match between the Entity Editor and the Attribute columns.
- When a component name contained curly braces, an application error occurred when setting the component as current.
