Connectors
New Features
Auto Area Tools
This feature can be used to select Parts/Components and create Area Connectors within the a specified Tolerance. The result will mirror the result from the Auto Contact tool.
Capture Shape Attachments
These new attachment options allow a shape selection and dimensioning. Any nodes within the selection on the part link is then selected. The different shapes are sphere, box, and cylinder.
Contact Connectors
This feature can be used to create contacts from the connector. This realization creates set-based contacts between areas identified by the connector projection. This is supported from both line and area connectors.
Figure 3.
Enhancements
Assembly Migration
Assembly links are now migrated to group links containing all of the components in the assembly.
Connector Graphics
The connector graphics for area connectors have been overhauled.
There should now be significantly improved frame rate when zooming, panning, and adjusting models with large numbers of connectors.
Miscellaneous
New attributes have been added to connectors to access more projection information for customization.
Improved direction recognition for Seam Quad when realizing on T edges.
Improved partitioning of the connectors over small gaps between parts.
Hemming has been renamed to match point connectors as RBE3(Load Transfer).
Add Links now remembers the previous settings from within a session.
An option added to organize the Connector to it's base part during creation.
Position connectors now works for all connector types.
Seam Quad realization now supports Tab/Slot type configuration.
ANSYS and PAM-CRASH realizations have been renamed to match the other solver profile realization naming convention.
RJOINTS and DOF have been exposed for fastener realization types.
An additional solid selector has been added to support point line creation.
Rebuild is now available as an option for area connectors.
Resolved Issues
  • Hole type realizations are no longer failing with an open hole.
  • Partially skinned solids are now treated as a single link during realization.
  • The vector attribute on a connector now reacts appropriately to the Move tool.
  • Solid fasteners now create a system when the option is selected.
