No Load curve + Back-emf
Positioning and objective
The aim of the test “Characterization - Open circuit – Generator – No Load” is to characterize the behavior of the machine when running in a no–load state.
In such a case, it is recommended to perform a transient computation in Flux® environment. The application “Export to Flux” allows exporting the model with the corresponding scenario ready to be solved.
| Characterization - Open circuit – Generator – No Load - Overview |
User inputs
The maximum field current value and the rotation speed are the only necessary standard input parameters to run this test. The operating temperature of the field winding and damper bars, if existing, can be defined in the settings “Thermal”.
Additionally, if the user wants to run a complete back-emf test for a single point, specified with a field current value, the two concerned inputs are available as standard inputs as well.
Main outputs
Test results are illustrated with data, graphs and tables.
- No-load characteristics - Phase voltage rms value versus the field current value – No-load (line graph and table)
- Machine performance – Open circuit, Back-EMF characteristics (voltage constant and voltage magnitudes), Flux linkage, Flux in airgap, Flux density in iron
- Phase voltage (Phase voltage versus time – Open circuit, Phase voltage harmonic analysis – Open circuit (bar graph and table))
- Line-line voltage (Line-line voltage versus time – Open circuit, Line-line voltage harmonic analysis – Open circuit (bar graph and table))
- Flux density in airgap (Flux density in the airgap versus angular position – Open circuit, Flux density in the airgap harmonic analysis – Open circuit (bar graph and table))
- Flux linkage (Flux linkage versus angular position – Open circuit)
| Characterization - Open circuit – Generator – No Load – The main outputs |
