Make a report
Overview
The aim of this export is to build and quickly export a report showing all the work achieved to design and test the machine.
As a result, the report can be exported in a pdf or html file format. It can also be attached to the motor in the "Motor Catalog" or simply displayed in the report area.
Area to build the report
| Motor Factory - EXPORT area - Export a report | |
| 1 | Selection of the EXPORT area of Motor Factory. |
| 2 | Access the area in which a report can be made |
| 3 | Zone to visualize the report (= preview) |
| 4 | 4 steps to build the report |
| 5 | Buttons to validate inputs, display a preview and export a report |
Steps to build and export a report
Five steps are needed to build and export a report: In EXPORT / DOCUMENT / REPORT
                area:
        - Select the sections to write dealing with the design
- Select the sections to write dealing with the tests
- Select the sections to write dealing with the materials
- Select the “saved test results” you want to add as archive in the report
- Define the export information
