1. Standard inputs
- Line current, rmsThe line current supplied to the machine: “Line current, rms” ( Line current, rms value ) must be provided.
- Control angleConsidering the vector diagram shown below, the “ Control angle ” is the angle between the electromotive force E and the electrical current (J) (Ψ = (E, J)). It is an electrical angle. The default value is 45 degrees. It must be set in a range of -90 to 90 degrees. This range of values covers all the possible working point in motor convention.
 Definition of the control angle Ψ - Motor convention
2. Advanced inputs
The list of advanced inputs dedicated to this export are listed below.
For more details please refer to the list of generic advanced inputs.
- Rotor initial position modeBy default, the “ Rotor initial position mode ” is set to “ Auto ”.
                Mesh order The default level is second order mesh.
                Airgap mesh coefficient Airgap mesh coefficient is set to 1.5 by default
