Standard inputs
Speed
The speed of the machine to be considered.
Set of losses
The losses to be defined are the following ones:
        - Stator Joule losses
- Stator iron losses
- Rotor iron losses
- Mechanical losses
Time definition
The time during which the test is performed, defined by:
        - Maximum evaluation duration
- Time step
Advanced inputs
There are no advanced inputs required for this export.
