Export a script
Overview
Next to the function “Report”, the function “Script” gives the capability to build and to export a python script file in which all the needed command lines are written to rebuild the considered motor. The script is generated with all the needed sections and sub-sections in Motor Factory, dedicated to design, to the test, and the exports.
Then Script Factory can be used to automate some study such like running serial tests or serial design configurations.
Area to build the script export
| Motor Factory – EXPORT AREA – Export a python script | |
| 1 | In Motor Factory select EXPORT / SCRIPT environment. |
| 2 | The EXPORT / SCRIPT environment user input allows to define the
                                name and the location of the new script file + the name of the motor
                                to be rebuilt from the new python script file, with the catalog name
                                in which it will be stored. Note: Without
                                    defining other names for the motor and/or the catalog, the
                                    original motor would be overwritten while running the new python
                                    script file. |
| 3 | Button to build and to export the resulting python file. |
| 4 | Button to build and to export the resulting python file, and then to open it directly and automatically in Script Factory |
