Fast import
The import button allows sharing the data simulated in Flux between model map and efficiency tests.
By implementing the rotor position dependency option for the model map test and efficiency map test of synchronous machines, this update facilitates the seamless transfer of settings, inputs, and crucially, simulated data in Flux between the two tests. As they use the same Flux data in most cases and significant computation time is required to obtain it, users can now accelerate the test resolution and optimize their workflow.
- Reluctance Synchronous Machines - Inner rotor
- Synchronous Machines with wound field – Inner Salient Pole - Inner rotor
Upon completing a model map test, users can activate the import button in the efficiency map test GUI. This enables them to effortlessly import the settings and corresponding Flux data from the previous test, eliminating the need to rerun Flux for identical data, a step that typically consumes a substantial portion of computation time during efficiency mapping.
Import function in Model Map test and Efficiency Map test to accelerate test resolution | |
1 | Open model map test environment when an efficiency map test is available for import |
2 | Click the import button and import the settings, inputs, and Flux data of the latest efficiency map test |
3 | Open efficiency map test environment when a model map test is available for import |
4 | Click the import button and import the settings, inputs, and Flux data of the latest model map test |
