Table
List of working points
Two ways are possible to define the list of working points: either filling the table line per line or by importing an Excel file in which all the working points to be considered are defined.
Table 1. User working point analysis = Duty cycle
1 Click on the button “Set values” of the field “User working point list” to define the working points in a dialog box.
1.1 Dialog box opened after having clicked on the button “Set values” in the field “Cycle description”.
1.2 Browse the folder to select an Excel file which describes the duty cycle.
1.3 Button to refresh the table data when the considered Excel file has been modified.
1.4 Fields to be filled with data to describe the duty cycle to be considered.
1.5 Excel file template to define the list of working points.
Note: There must be at least two working points.
Note: The speed column must contain increasing speeds.
