T - N
Positioning and objective
The aim of the test “Mechanics – NVH – Spectrogram – T-N” is to perform NVH analysis on the machine when operating at a set of targeted working points defined with the following inputs values T, N (Mechanical torque and Speed).
Figure 1. Characterization of the corner point on the torque-speed curve
Input parameters like the maximum “Line-Line voltage”, the maximum “line current” and the desired “Maximum speed” of the machine are considered.
Two types of command modes are available: The Maximum Torque Per Volt command mode (MTPV) and the Maximum Torque Per Amps command mode (MTPA).
Input parameters allow us to define torque-speed envelope in the framework of which the targeted working points can be selected.
By default, the NVH evaluation is computed by considering working points on the torque-speed envelope.
But one can define a list of working points located anywhere under (or on) the torque-speed envelope.
This test gives data allowing NVH prediction in early electromagnetic and design stage.
The modal analysis of the stator mechanical structure, the radiated sound power spectrogram per engine order and versus speed and the resulting overall weighted radiated sound power versus speed are computed and displayed.
These results allow to see if there are any problem linked with NVH overall the considered speed range.
And finally, this test helps to answer the following question: Could the machine have any risks in connection with NVH? Yes / No.
The following table helps to classify the test “Mechanics – NVH – Spectrogram – T-N”.
Table 1. Positioning of the test “Mechanics – NVH – Spectrogram – T-N”
Family Mechanics - NVH
Package Spectrogram
Convention Motor
Test T, N
Subsections
For more details, please refer to Inputs.
Thermal
For more details, please refer to Thermal.
Electronics
For more details, please refer to Electronics.
Mechanics
For more details, please refer to Mechanics.
