Table
| 1 | Click on the button “Set values” of the field “ I, Ψ, N description” to define the working points in a dialog box. Refer to the next illustration which shows how to fill the working point table. |
| 1.1 | Dialog box opened after having clicked on the button “Set values” in the field “Cycle description” |
| 1.2 | Browse the folder to select an Excel file which describes the duty cycle |
| 1.3 | Button to refresh the table data when the considered Excel file has been modified |
| 1.4 | Fields to be filled with data to describe the duty cycle to be considered |
| 1.5 | Excel file template to define the list of working points |
Note: There must be at least two working points.
Note: The speed column must contain increasing speeds.
