Thermal
This dialog box allows us to define the temperature of active components.
For the considered test, these settings concern the temperature of the winding and magnets. In the thermal settings you have two main possible choices:
  • You can define the temperatures of the winding to define the physical properties of the materials needed to run directly the tests without any thermal computation.
  • Or you can perform a thermal solving. This means that it will be possible to consider the impact of the magnet temperature in a predefined range of temperature.
Settings
For more details, please refer to Thermal for SMPM
