AP Card
This card defines a planar, cylindrical or spherical aperture of measured or calculated field values that is converted by PREFEKO internally into an equivalent array of electric and magnetic dipoles (A5/A6 cards).
On the Source/Load tab, in the Equivalent sources group, click the  Aperture source (AP) icon.
Figure 1. The AP - Define an aperture field source dialog.
Parameters:
New source
A new excitation is defined which replaces all previously defined excitations.
Add to sources
A new excitation is defined which is added to the previously defined excitations.
Combine with previous sources
Combine multiple aperture field definitions to create a single near field source.
Load field data from
Feko Solver (*.efe/*.hfe) file
Read the field values from .efe/.hfe format files calculated by Feko. The files should contain values describing a single face. The field data files are requested with the DA card.
Cartesian boundary from Feko Solver (*.efe/*.hfe) file
Read the field values from .efe/.hfe format files calculated by Feko. The files should contain values describing a Cartesian boundary. The field data files are requested with the DA card.
CST near field scan (CST NFS)
Read the field values from CST NFS format files.
Sigrity (*.nfd) input file
Read the field values from a .nfd file.
MVG (*.mfxml) measurement file
Read the field values from a .mfxml file.
ASCII text file
Read the field values from an ASCII file.
The field data follows in the (*.pre) input file
The field values are specified in the .pre file. The format of this file is described with the AR card.
Aperture orientation
Here one may select a planar, cylindrical or spherical aperture. For a planar aperture one may elect to use only electric or magnetic fields (this radiates in both directions, see comments below).
Also sample along edges
This item is used to determine if dipoles are allowed to be positioned on the edges of the aperture or not (see figures below). When checked the outer dipoles will be positioned exactly on the edges. When unchecked the dipoles will be positioned half an increment away from the edges. Dipoles should not be positioned on the edges of two apertures that have a common side, otherwise two dipoles may have the same location and polarisation. If this is the case the power calculation in Feko will fail.
Swap source and field validity regions
This item is used for Cartesian boundary, spherical and cylindrical apertures to interchange the side of the aperture where the fields are considered equivalent to the field values being loaded (previously measured or calculated fields). By default (if not selected), it is assumed that the original source is inside the aperture region and the near field data represents the fields outside that region.
S1, S2 and S3
These text boxes are for input points (see the DP card) that define the orientation of the aperture. The figure on the dialog will depict the orientation. For a planar aperture the input points define the position of the origin and the direction of the u ^ 2 and u ^ 3 directions respectively. (The field data is assumed to vary first along the u ^ 2 direction.) For cylindrical and spherical apertures they define the origin and the direction of the local Z axis and X axis respectively. All angles are relative to these axes.
E-field file name
The input file name from which the electric field data must be read. This may be either an .efe file or a text file (with units V/m).
H-field file name
The input file name from which the magnetic field data must be read. This may be either an .hfe file or a text file (with units A/m).
File name
The input file name from which the Sigrity (.nfd) or MVG (.mfxml) files are read.
Use all data blocks
Import all data blocks from the specified .efe/.hfe, .nfs, .nfd or .mfxml file. The data is interpolated for use at the operating frequency.
Use only specified data block number
Use the data from the nth frequency block in the specified .efe/.hfe, .nfs, .nfd or .mfxml file.
Use specified start point and range
Select a specific near field pattern in a .efe/.hfe (a single face), .pre or ASCII text file.
Start from point number
The number of the first field point to be used for the aperture. If set to 1, field values are read from the start of the file, for larger values the first point number-1 values (.efe and .hfe files) or lines (text files) are ignored. This may be used, for example, if the data file contains the field values for more than one frequency. This corresponds to the line number if all non-data lines are stripped from the file. The Start from point number field is not used if the field data is obtained from the .pre input file
Number of points along...
These two text boxes specify the number of field points along each of the two axes of the aperture.
Include fields on boundary
When importing Cartesian boundary near field data from file, a face (or faces) of the near field boundary can be ignored. Clear the relevant check box to exclude the face.
Amplitude scale factor
A constant by which the amplitudes of all the dipoles in the aperture are scaled.
Phase of aperture
A constant phase added to all dipoles in the aperture.
The aperture is based on the equivalence principle. This states that the sources and scatterers inside a given volume can be removed, and modelled by placing the equivalent currents J s = n ^ ×H and M s =− n ^ ×E on the enclosing surface. The vector n ^ is a unit vector, normal to the surface, and points towards the exterior region. The fields in this region are the same as the original fields, while those in interior region are zero.
Field values are read from the data files (with a possible offset specified with Start from point number) or the .pre input file and converted to equivalent electric (magnetic fields) and magnetic (electric field) dipoles at these points.
Note: All angles are read from the data, but no distance values.
Therefore for planar apertures the positions are calculated entirely from the specified points (S1, S2 and S3). For cylindrical apertures the specified points (S1 and S2) define the extents of the aperture along the local z ^ direction and S1–S3 specifies the direction of the X axis as well as the radius of the cylinder. The points are placed at the φ -values listed together with the field data. For spherical apertures, S1–S2 specifies the direction of the Z axis and S1–S3 the X axis. S2 and S3 must be positioned on the same radius which is also the radius of the field points. In this case both ϑ and φ are read with the data.
Figure 2 and Figure 3 show the application of the equivalence principle to a planar aperture. In both figures there are the same number of field points along the two orthogonal directions. If the Also sample along edges check box is selected, the first point is positioned at S1 with the following points in the direction of S2 as shown by the indices. When the Also sample along edges check box is cleared, the first point is positioned offset from S1. The normal vector is calculated from n ^ = u ^ 2 × u ^ 3 with u ^ 2 and u ^ 3 as defined in the figure.
Figure 2. Location of the equivalent dipoles on a planar aperture where the Also sample along edges check box is selected.
Figure 3. Location of the equivalent dipoles on a planar aperture where the Also sample along edges check box is cleared.
In Figure 4, dipole locations for a cylindrical aperture created from a data file containing field values for φ from 20° to 80° in 10° increments and 5 values in the z direction. When the Also sample along edges check box is selected, the samples extend up to the edges of the aperture. When the Also sample along edges check box is cleared, samples are not positioned on the edges.
Note: With regards to selecting or clearing the Also sample along edges check box, with the option selected, the z positions of the samples will increase the height of the effective aperture, while in the φ direction the size of the effective aperture is increased by 5° on both sides.
Figure 4. Location of the equivalent dipoles on a cylindrical aperture: (a) Also sample along edges check box is selected (b) Also sample along edges check box is cleared.
In Figure 5, the dipole locations for a spherical aperture created from field values for ϑ from 40° to 80° with 10° increments and φ from 20° to 80° also with 10° increments. In this case the aperture increases in size in both directions when selecting the Also sample along edges check box.
Figure 5. Location of the equivalent dipoles on a spherical aperture: (a) Also sample along edges is checked (b) Also sample along edges is unchecked.
For planar apertures, the data must vary first along the u ^ 2 direction. For cylindrical and spherical apertures PREFEKO will determine which coordinate is incremented first and write out the dipoles accordingly.
The dipole amplitude is the product of the surface current and the incremental area between samples. In addition, the amplitude of the dipoles on the sides (when checking Also sample along edges) are reduced by a factor of 2 and those on the corners by a factor of 4 to ensure that the effective aperture of integration has the same size as the specified aperture.
A fully closed surface can be created by specifying 6 planar apertures or a spherical one. The surface equivalence principle can be applied to this surface by reading both electric and magnetic fields for each plane. (For planar apertures the user should specify 6 AP cards, each using both electric and magnetic fields. If separate cards are used for the electric and magnetic fields the radiated power is not calculated correctly.) The normal vector must point towards the exterior region, which is normally outward. (For planar apertures created from .efe and .hfe files, the sample order determines the directions of u ^ 2 and u ^ 3 which, in turn, determines the normal vector n ^ = u ^ 2 × u ^ 3 . If this is pointing into the cube, an additional 180° phase shift is obtained by setting Phase of aperture (degrees) to 180. This changes the sign of the field radiated by the aperture which, when interacting with the remaining sources, will result in the correct total fields in the desired region. All surfaces and scatterers inside the body must be removed but not those on the outside.
For planar apertures (for example, the opening of a horn antenna), one may use the mirror principle if the field at the edges can be neglected. This results in a duplication of the magnetic current and cancellation of the electric current. Therefore it is sufficient to read only the electric fields and scale by the factor Amplitude scale factor=2. In this case any sources or structures in the region towards which the normal is pointing should also be subjected to the mirroring (the structures should be electrically mirrored by using the SY card).
Note: The fields will only be correct in the direction that the normal vector points to. The symmetric fields in the other half-space will not be equal to the fields of the original problem.
Feko takes this application of the mirror principle into account and divides the total radiated power by two when calculating the power radiated by a planar aperture containing only electric or magnetic fields.
