/MAT/LAW72 (HILL_MMC)
Block Format Keyword Describes the anisotropic Hill material with a modified Mohr fracture criteria. This law is available for shell and solid.
/MAT/LAW72/mat_ID/unit_ID or /MAT/HILL_MMC/mat_ID/unit_ID | |||||||||
mat_title | |||||||||
ρiρi | |||||||||
E | v | ||||||||
σ0yσ0y | ε0pε0p | n | F | G | |||||
H | N | L | M | ||||||
C1 | C2 | C3 | m | Dc |
Definition
mat_ID | Material identifier. (Integer, maximum 10 digits) |
unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
mat_title | Material title. (Character, maximum 100 characters) |
ρiρi | Initial density. (Real) |
[kgm3][kgm3] |
E | Initial Young's modulus. (Real) |
[Pa][Pa] |
v | Poisson's ratio. (Real) |
σ0yσ0y | Initial yield stress. Default = 1020 (Real) |
[Pa][Pa] |
ε0pε0p | Initial plastic strain. Default = 10-20 (Real) |
n | Exponent for the isotropic function for the swift hardening: σy=σ0y(εp+ε0p)nσy=σ0y(εp+ε0p)n It is also used as an exponent in the MMC failure equations. 2 Default = 1.0 (Real) |
F, G, H, L, M, N | Six
HILL Materials anisotropic parameters (>
0). (float) |
C1 | First parameter for MMC fracture model. (Real) |
C2 | Second parameter for MMC fracture model. Default = σ0yσ0y (Real) |
[Pa][Pa] |
C3 | Third parameter for MMC fracture model. (Real) |
m | Exponent for the softening function. 3 Default = 1.0 (Real) |
Dc | Critical damage.
(Real) |
▸Example (Metal)
- 3D equivalent Hill
stress:f=√F(σyy−σzz)2+G(σzz−σxx)2+H(σxx−σyy)2+ 2Lσ2yz+2Mσ2zx+2Nσ2xyf=√F(σyy−σzz)2+G(σzz−σxx)2+H(σxx−σyy)2+2Lσ2yz+2Mσ2zx+2Nσ2xy
For shell element, take:
f=√Fσ2yy+Gσ2xx+H(σxx−σyy)2+2Nσ2xyf=√Fσ2yy+Gσ2xx+H(σxx−σyy)2+2Nσ2xy - MMC fracture
criteria:D=εp∫0dεpεf(θ,η)D=εp∫0dεpεf(θ,η)Withεf(ˉθ,η)={σ0yC2[C3+√32−√3(1−C3)(sec(ˉθπ6)−1)][√1+C213cos(ˉθπ6)+C1(η+13sin(ˉθπ6))]}−1nεf(¯θ,η)=⎧⎨⎩σ0yC2[C3+√32−√3(1−C3)(sec(¯θπ6)−1)]⎡⎣√1+C213cos(¯θπ6)+C1(η+13sin(¯θπ6))⎤⎦⎫⎬⎭−1n
- For 3D solid elements
ηη is stress triaxiality with η=13(σxx+σyy+σzz)σVMη=13(σxx+σyy+σzz)σVM
ˉθ¯θ is shift Lode angle ˉθ=1−2πarcosζ¯θ=1−2πarcosζ
with Lode angle ( θθ ) parameter ζ=cos(3θ)=272J3σ3VMζ=cos(3θ)=272J3σ3VM
J3J3 is the third invariant of the deviatoric stress.
- For shell elements
with Lode angle ( θθ ) parameter ζ=cos(3θ)=−272η(η2−13)ζ=cos(3θ)=−272η(η2−13)
- Fracture and damage with MMC
fracture criteria:
- When D = 1: fracture initiate
- By 1 < D <
Dc: the yield stress is multiplied
by softening function
ββ
to reduce the deformation resistance.
σy=βσ0y(εp+ε0p)nσy=βσ0y(εp+ε0p)n with β=(Dc−DDc−1)m0<β<1β=(Dc−DDc−1)m0<β<1
- If D ≥ Dc, the element is deleted.
- The exponent m is used to describe the softening behavior. It is
recommended to use m > 0.
If 0 < m < 1, then the softening curve is convex.
If m > 1, then the softening curve is concave. The softening is between εfεf and Dc⋅εfDc⋅εf . Once the plastic strain is reached Dc⋅εfDc⋅εf (in this case D>DcD>Dc ), then the element is deleted.Figure 2. Figure 3.
- It is possible to display user
variables in animation files (with Engine /ANIM/Eltyp/Restype) and in Time history file (with Starter /TH/SHEL and /TH/BRIC):
- USER1: Damage value
- It is also possible to display a normalized damage variable Dn=DDcDn=DDc in animation files with /ANIM/BRICK/DAMG, /ANIM/SHELL/DAMG, /H3D/SHELL/DAMG and /H3D/SOLID/DAMG.
