/MAT/LAW48 (ZHAO)
Block Format Keyword This law describes the Zhao material law used to model an elasto-plastic strain rate dependent materials. The law is applicable only for solids and shells.
The global plasticity option for shells (N=0 in shell property keyword) is not available in the actual version.
/MAT/LAW48/mat_ID/unit_ID or /MAT/ZHAO/mat_ID/unit_ID | |||||||||
mat_title | |||||||||
ρi | |||||||||
E | ν | ||||||||
A | B | n | Chard | σmax | |||||
C | D | m | EI | k | |||||
˙ε0 | Fcut | ||||||||
εmaxp | εt1 | εt2 |
Definition
mat_ID | Material identifier. (Integer, maximum 10 digits) |
unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
mat_title | Material title. (Character, maximum 100 characters) |
ρi | Initial density. (Real) |
[kgm3] |
E | Young's modulus. (Real) |
[Pa] |
ν | Poisson's ratio. (Real) |
A | Plasticity yield
stress. (Real) |
[Pa] |
B | Plasticity hardening
parameter. (Real) |
[Pa] |
n | Plasticity hardening exponent. Default = 1.0 (Real) |
Chard | Plasticity Iso-kinematic hardening factor.
Default = 0.0 (Real) |
σmax | Plasticity maximum stress. Default = 1030 (Real) |
[Pa] |
C | Relative strain rate
coefficient. Default = 1.0 (Real) |
[Pa] |
D | Strain rate plasticity factor. Default = 0.0 (Real) |
m | Relative strain rate exponent. Default = 1.0 (Real) |
EI | Strain rate coefficient. Default = 0.0 (Real) |
[Pa] |
k | Strain rate exponent. Default = 1.0 (Real) |
˙ε0 | Reference strain
rate. (Real) |
[1s] |
Fcut | Cutoff frequency for strain rate
filtering. Default = 0.0 (Real) |
[Hz] |
εmaxp | Failure plastic strain. Default = 1030 (Real) |
εt1 | Tensile failure strain 1. Default = 1030 (Real) |
εt2 | Tensile failure strain 2. Default = 1030 (Real) |
▸Example (Metal)
- The stress-strain function is based
on the formula published by Zhao:σ=(A+Bεpn)+(C−Dεpm)⋅ln˙ε˙ε0+E1˙εkWhere,
- εp
- Plastic strain
- ˙ε
- Strain rate
- Except for the strain rate
formulation, the plasticity curve is strictly identical to a Johnson-Cook model:
Figure 1. However, compared to Johnson-Cook, the Zhao law allows a better approximation of a nonlinear strain rate dependent behavior.
- Yield stress should be strictly positive.
- The hardening exponent
n must be less than 1.
Figure 2. - The iso-kinematic hardening
parameter is defined as:
- If Chard = 0, hardening is a full isotropic model
- If Chard = 1, hardening uses the kinematic Prager-Ziegler model
- If 0 < Chard < 1, hardening is interpolated between the two models
- If
˙ε≤˙ε0
, the term
(C−Dεpm)⋅ln˙ε˙ε0=0
, and Equation 1 becomes: σ=(A+Bεpn)+E1˙εk
- The strain rate filtering is used to smooth strain rate. It is only available for shell and solid elements.
- When
εp
reaches
εmax
in one integration point, then based on the element type:
- Shell elements: The corresponding shell element is deleted.
- Solid elements: The deviatoric stress of the corresponding integral point is permanently set to 0, however, the solid element is not deleted.
- If
ε1>εt1
ε1
is the largest principal strain), the stress is reduced
as:σn+1=σn(εt2−ε1εt2−εt1)
- If ε1>εt2 , the stress is reduced to 0 (but the element is not deleted).
