/FAIL/WILKINS
Block Format Keyword Describes the Wilkins failure model.
/FAIL/WILKINS/mat_ID/unit_ID | |||||||||
α | β | Plim | Df | Ifail_sh | Ifail_so |
Optional Line
fail_ID |
Definition
mat_ID | Material
identifier. (Integer, maximum 10 digits) |
unit_ID | Unit Identifier. (Integer, maximum 10 digits) |
α | Hydrostatic pressure
exponent. (Real) |
β | Deviatoric
coefficient. (Real) |
Plim | Hydrostatic pressure
limit. (Real) |
[Pa] |
Df | Critical
damage. (Real) |
Ifail_sh | Shell failure flag.
(Integer) |
Ifail_so | Solid failure flag.
(Integer) |
fail_ID | Failure criteria identifier. 2 (Integer, maximum 10 digits) |
▸Example (Metal)
- The cumulative
damage is:
Dc=∫W1W2dˉεp
Where,
W1=(11+aP)α
a=−1Plim
Where,- P
- Hydro pressure
P=−133∑j=1σjj
W2=(2−A)β
A=max(s2s1,s2s3), s1≥s2≥s3
Where, s1,s2,s3 are the deviatoric stresses.
- The fail_ID is used with /STATE/BRICK/FAIL and /INIBRI/FAIL. There is no default value. If the line is blank, no value will be output for failure model variables in the /INIBRI/FAIL (written in .sta file with /STATE/BRICK/FAIL option).
