Remove Solid Holes
Use the Defeature: Holes tool to remove solid holes in the model.
Note: FE geometry is not supported for this
tool.
From the Topology ribbon, click the tool.
Figure 1. - Optional:
On the guide bar, click
to define settings used to find and select holes of a specific size.
On the guide bar, click Find.
Holes in the model are selected and highlighted red.
Review each found hole by clicking
and
on the guide bar.
- If you have already used the Features tool to detect solid holes, you can use the drop-down on menu on the guide bar to select them directly.
Remove holes in the following ways:
- Remove all found/selected holes by clicking Remove All.
- Remove individual holes by left-clicking.
