Perform Batch Repair
Use the Defeature: Batch tool to perform automatic cleanup operations on selected surfaces.
Note: FE geometry is not supported for this
tool.
From the Topology ribbon, click the tool.
Figure 1. -
On the guide bar, click
to define batch repair options and review parameter and criteria files.
- Make any necessary changes to parameter file options based on your requirements.
- Select surfaces to clean up.
- On the guide bar, click Batch Repair.
Note: Criteria and Parameter files can be loaded in the session
using the Param/Criteria tools on the Mesh ribbon. These files are accessible to all
the tools that require them and can be accessed from links in the options
menu.
For Batch Repair, the parameter file is launched exposing only the geometry cleanup options. Meshing related options are hidden from as only geometry cleanup is done using this tool.
