Remove Cuts and Edge Fillets
Use the Defeature: Cuts/Edge Fillets tool to extend surface edges and remove cutouts, fillets, and rounds.
From the Topology ribbon, click the tool.
Figure 1. -
Select lines, locations, or surfaces.
Option Description Lines Select surface edges to remove cuts. Left-click highlighted lines to remove individual cuts or click
on the guide bar to remove all at once.
Locations Select two locations on surface edges to remove cuts. Surfaces Select surfaces to remove fillets and rounds. Similar to surface fillets, edge fillets create smooth curves at the intersection of relatively perpendicular free edges.
An edge fillet is a part of the trimming loop of a surface that can be roughly equivalenced to a circular arc.Figure 2. Edge Fillets - Click
to define the min/max radius and the minimum angle.
- From the drop-down menu, select whether to find Rounds, Fillets, or All.
- Click Find on the guide bar.
Rounds and fillets in the model are selected and highlighted red.
After the fillets are detected, you can change the detection parameters. Fillets/rounds that do not meet new criteria are then deselected. However, detection of additional fillets that meet a lesser criterion is not performed unless you click Find again.
Tip: You can also select surfaces manually without using automatic detection. - Review each selected round/fillet by clicking
and
on the guide bar.
- Left-click highlighted rounds/fillets to remove them
individually or click
Current implementation does not detect or process fillets that belong to different surfaces or span across different suppressed surfaces.
- Click
