Rename a Derived Load Case
Do one of the following:
- Click the Loadcase tool.
Figure 1. - Right-click in the Results Browser and select then a load case type.
The Create/Edit Derived Load Case dialog is displayed. - Click the Loadcase tool.
- From the Derived load case drop-down menu, select a load case to make it active.
Click Rename.
The Rename dialog is displayed.
- Type a new label in the text field and press Enter.
