Delete a Derived Load Case
Do one of the following:
- Click the Loadcase tool.
Figure 1. - Right-click in the Results Browser and select then a load case type.
The Create/Edit Derived Load Case dialog is displayed. - Click the Loadcase tool.
- Select a load case from the Derived load case drop-down menu in order to make it active.
Click Delete.
The last derived load case that remains in the list becomes the active derived load case.
