Remove Load Cases or Simulations from a Derived Load Case
Do one of the following:
- Click the Loadcase tool.
Figure 1. - Right-click in the Results Browser and select then a load case type.
The Create/Edit Derived Load Case dialog is displayed. - Click the Loadcase tool.
- Select one or more simulation time steps from the derived load case list.
Click the left blue arrow
(remove button).
The simulation time steps are removed from the list.
