poIQueryIgnoreElemTypeRule GetSelectionSetList
Gets the selection set locator stringlist.
rule_handle GetSelectionSetList
HyperView Tcl Query
This command is used to get the selection set locator stringlist.
To get the selection set locator
stringlist:
hwi OpenStack
hwi GetActiveClientHandle client
set ruleID [client AddQueryRule ignoreelemtype]
client GetQueryRuleHandle rule_handle $ruleID
rule_handle SetSelectionSet "User_Set 6"
set advQueryID [client AddAdvancedQuery]
client GetAdvancedQueryHandle advancedQuery_handle $advQueryID
advancedQuery_handle AddSimulations "current" "current"
advancedQuery_handle SetQuery "entity.id entity.value"
advancedQuery_handle SetQueryLogic "[rule_handle GetID]"
advancedQuery_handle GetValueList
hwi CloseStack
This command returns an empty string "", if there are no sets selected.
