poIQueryIgnoreElemTypeRule GetElementTypeList
Gets the element type list from the advanced query.
rule_handle GetElementTypeList
HyperView Tcl Query
This command is used to get the element config type list from the advanced query.
To get the element config type list from the advanced
query:
hwi OpenStack
hwi GetActiveClientHandle client
set ruleID [client AddQueryRule ignoreelemtype]
client GetQueryRuleHandle rule_handle $ruleID
rule_handle SetElementTypeList "rigidlink Quad4"
hwi CloseStack
This command returns HW_InvalidHandle
, if the core object associated with
the advanced query handle does not exist anymore.
