2024
View new features for version 2024.
The Python API documentation for HyperMesh applications.
Gets the element type list from the advanced query.
Gets the number of adjacent elements to ignore from the advanced query.
Gets the selection set locator stringlist.
Sets the element type list to elements from the advanced query.
Sets the number of adjacent elements to ignore.
Sets the selection set to the advanced query.
Use the Task Manager to load an XML file that defines tasks and their attributes.
