*move_feature
Moves a selection of elements and pastes them onto the displayed shell elements at the target location.
*move_feature entity_type mark_id string_array number_of_strings
HyperMesh Tcl Modify Command
Moves a selection of elements and pastes them onto the displayed shell elements at the target location. The neighborhood of the pasted region will be remeshed. If the selected entities are connected to another mesh at the source, they are detached from them. Any holes left behind are patched and remeshed. Doesn’t allow moving elements associated to geometry.
- entity_type
- The type of entity to copy. Valid values are components and elements. The selection may consist of shell or solid elements. Any 1D elements attached to shell elements are automatically included.
- mark_id
- The ID of the mark of entities. Valid values are 1 and 2.
- string_array
- The ID of the string array that contains the additional input parameters. The string array is created using the *createstringarray command. This should always be set to 1.
- number_of_strings
- Integer indicating the size (number of strings) in the string array created using *createstringarray.
To move elements 5100-5200 along the -y direction with a distance of 1, and remeshing 2 layers with the rebuild algorithm:
*createstringarray 5 "TransformByMatrix : 0 -1 0 0 1 0 0 0 0 0 1 0 0 0 0 1 " "MappingMethod : morph" "Rebuild : 1" "NumLayers : 2"
*createmark elements 1 5100-5200
*copy_feature elements 1 1 5
# Handle error
Version History
2019.1
2021 - Added new string_array options MappingMethod and StitchBoundary. Deprecated string_array option MorphFeatureToBase.
