*create_solid_from_eight_points
Creates a solid from eight points.
*create_solid_from_eight_points Point1=<value> Point2=<value> Point3=<value> Point4=<value> Point5=<value> Point6=<value> Point7=<value> Point8=<value>Type
HyperMesh Tcl Modify Command
Creates a solid from eight points. You must provide eight coordinates in the order shown
below.
All <option>=<value> options should be specified in the exact order; all options are mandatory.
- Point1=<value>
- The double values corresponding to each global x, y, and z coordinates of the box for corner1.
- Point2=<value>
- The double values corresponding to each global x, y, and z coordinates of the box for corner2.
To create a solid defined by eight corner
*create_solid_from_eight_points Point1={-26.31670 -18.981850 16.617546} Point2={-26.31670 30.518150 16.617546} Point3={-3.097893 -18.981850 16.617546} Point4={-3.097893 30.518150 16.617546} Point5={-26.31670 -18.981850 37.217796} Point6={-26.31670 30.518150 37.217796} Point7={-3.097893 -18.981850 37.217796} Point8={-3.097893 30.518150 37.217796}
Incorrect usage results in a Tcl error. To detect
errors, you can use the catch
command:
# Handle error
Version History
2021.1
