*compute_midmesh_thickness
Calculates the thickness of a midmesh and assigns properties.
*compute_midmesh_thickness mesh_entity_type mesh_mark_id geom_entity_type geom_mark_id string_array number_of_strings
HyperMesh Tcl Modify Command
Computes the thickness of the midmesh elements based on the proximity with the geometry. New properties are created with thickness assigned. The command expects a baseline property with the name t0 to exist before execution. It estimates thickness and assigns the thicknesses to new properties, using the t0 property as a template. Optionally, an expected minimum and maximum thicknesses can be supplied, which will be used and a guide for the computation.
This functionality is currently supported for the OptiStruct, Radioss, Nastran, Abaqus, LS-DYNA and ANSYS user profiles.
- mesh_entity_type
- Entity type used for mesh input. Valid values are:
- Elements
- Components
- mesh_mark_id
- The ID of the mark containing the mesh input. Valid values are 1 and 2.
- geom_entity_type
- Entity type used for geometry input. Valid values are:
- solids
- surfaces
- elements
- components
- geom_mark_id
- The ID of the mark containing the geometry input. Valid values are 1 and 2.
- string_array
- The ID of the string array that contains the additional input parameters. The string array is created using the *createstringarray command. This should always be set to 1.
- number_of_strings
- Integer indicating the size (number of strings) in the string array created using *createstringarray.
Examples
*createmark elems 1 all
*createmark surfs 1 displayed
*createstringarray 2 {MinThickness: 0.1} {MaxThickness: 1.0}
*compute_midmesh_thickness elems 1 surfs 1 1 2
*createstringarray 14 "ThicknessOutputOption : PROPERTYONCOMPONENTS" "NeedOffset : 0" \
"ThicknessCorrectionMethod : Interpolation" "ConnectionInterpolationFactor : 1.0" \
"LogFile : C:/Users/ Temp/__ThicknessCalculationLog263.log" \
"CardImage : SHELL63p" "GroupingTolerance : 0.2" "NumDecimals : Automatic" \
"NumDecimalsOffset : Automatic" "MaxInclinationOfMidMeshWithSolid : 35" "MaxThicknessGradient : 2.0" \
"ThicknessMeasurementLocation : Default" "SkipOutsideMeshFromCorrection : 0" \
"MaxRelativeChordalDeviation : 0.1"
"LogFile : C:/Users/Temp/__ThicknessCalculationLog263.log" \
" CardImage : SECTYPE" "GroupingTolerance : 0.2" "NumDecimals : Automatic" \
# Handle error
Version History
11.0.101
2017.1 - New options AssignMidIntervalAsThickness, FixedInterval and StartThickness added to support thickness grouping into intervals.
2021.1 - New options RegroupThicknessVariationFactor,RenameRetainedComponents, and ThicknessAssignMethod to enhance thickness grouping. Removed ThicknessOutputOption value PropertyOnComponents.
