| Unused materials |
                            Checks if there any unused materials in the model. |
                            Lists all unused materials. |
                            Not supported. |
                            Opens the material card image of
                                /MAT/PLAS_TAB. |
                            | Strain rate coefficient equal to 0 for LAW2 |
                            Checks if the strain rate coefficient is equal to zero for
                                material LAW2. |
                            Lists all of the law2 materials that have a strain rate
                                coefficient equal to zero. |
                            Not supported. |
                            Opens the material card image of either
                                    /MAT/PLAS_JOHNS or
                                    /MAT/PLAS_ZERIL. |
                            | Bad strain rate order in Law36 |
                            Checks for bad strain rate order in material Law36. The strain
                                rate should be in increasing order. |
                            Lists all the law36 materials having bad strain rate
                                order. |
                            Not supported. |
                                /MAT/PLAS_TAB. |
                            | Material with zero density |
                            Checks if material density is equal to zero. |
                            Lists all of the materials that have zero density. |
                            Not supported. |
                            Opens the corresponding material card image. |
                            | Material with zero modulus |
                            Checks if material modulus is equal to zero. |
                            Lists all of the materials that have zero modulus. |
                            Not supported. |
                            | Material with Poisson's Ratio less than 0.001 |
                            Checks if material Poisson’s Ratio is less than 0.001. |
                            Lists all of the materials that have Poisson’s Ratio less than
                                0.001. |
                            Not supported. |
                            | Law2,4,15,27: C and Eps0 defined but F and F blank |
                            Checks for law2, 4, 15, 27: C and Epsdot0 are defined, and F and F are blank. |
                            Lists all materials that failed the check. |
                            Not supported. |
                            Opens the Entity Editor of the material
                                entity. |
                            | LAW25 Tsai-Wu: C and Eps0 defined but F and F blank |
                            Checks for law25, TSAI-WU: C12 and Epsdot0 are defined, and F and F are blank. |
                            Not supported. |
                                entity. |
                            | LAW25 Crasurv: any C and E0 defined but F, F blank |
                            Checks for law25, CRASURV: C (or any of c1t,c1c,c2t,c2c,c12t) and
                            Not supported. |
                                entity. |
                            | Law36,59,60: Nfunc > 0 but F and F blank |
                            Checks for law36, 59, 60: Nfunct > 0, and F and F are blank. |
                            Not supported. |
                                entity. |
                            | LAW44: C and p defined but F and F blank |
                            Checks for LAW44: C and p are defined, and F and F are blank. |
                            Not supported. |
                                entity. |
                            | Law48: C,K and E0 defined but F blank |
                            Checks for law48: C, K and Epsdot0 are defined, and F is blank. |
                            Not supported. |
                                entity. |
                            | Law52: C and P defined but F and F blank |
                            Checks for law52: C and p are defined, and F and F are blank. |
                            Not supported. |
                                entity. |
                            | Law65,77: Nrate or Nload > 1 but F and F blank |
                            Checks for law65, 77: Nrate/Nload > 1, and F and F are blank. |
                            Not supported. |
                                entity. |
                            | Law70: Nload > 1 but F and F blank |
                            Checks for law 70: Nload > 1, and F and F are blank. |
                            Not supported. |
                                entity. |
                            | Law74: Eps rate scale defined but F and F blank |
                            Checks for law74: Epsdot_scale is defined, and F and F are blank. |
                            Not supported. |
                                entity. |
                            | Law80: Ceps and Peps defined but F and F blank |
                            Checks for law80: Ceps and Peps are defined, and F and F are blank. |
                            Not supported. |
                                entity. |
                            | Mat and referenced curves not in same include |
                            Checks if a material and its referenced curves are in the same
                                include. |
                            Lists all of the materials that have curves that are not in same
                                include file as the material. |
                            Not supported. |
                                entity. |
                            | Parameter and material title with & |
                            Checks if a material name has "&" when a parameter is defined
                                in the model. |
                            Lists all materials whose name has "&" when a parameter is
                                defined in the model. |
                            Not supported. |
                                entity. |
                            | Material with invalid name |
                            Checks if a material name contains no more than 100 characters,
                                and does not begin with a "/". |
                            Lists all materials whose names are greater than 100 characters
                                or begin with "/". |
                            Not supported. |
                                entity. |
                            | Unused properties |
                            Checks if there are any unused properties in the model. |
                            Lists all of the unused properties |
                            Deletes unused properties. |
                            Not supported. |
                            | Section shell thickness |
                            Checks if section shell thickness is less than or equal to
                                zero. |
                            Lists all of the shell properties that have a section thickness
                                less than or equal to zero. |
                            Not supported. |
                            Opens the property card image of
                                /PROP/SHELL. |
                            | Beam or truss property with area less than or equal to 0 |
                            Checks if beam and truss properties have an area equal to
                                zero. |
                            Lists all of the beam and truss properties that have an area less
                            Not supported. |
                            Opens the corresponding truss or beam property card
                                image. |
                            | Beam property with inertia less than or equal to 0 |
                            Checks if beam properties have an inertia less than or equal to
                                zero. |
                            Lists all of the beam properties that have inertia less than or
                                equal to zero. |
                            Not supported. |
                                /PROP/BEAM. |
                            | Spring property with inertia less than or equal to 0 |
                            Checks if spring properties have an inertia less than or equal to
                                zero. |
                            List all the spring properties that have an inertia less than or
                                equal to zero. |
                            Not supported. |
                                /PROP/SPRING. |
                            | Spring properties with null mass |
                            Checks if spring properties have null mass. |
                            Lists all of the spring properties that have null mass. |
                            Not supported. |
                                /PROP/SPRING. |
                            | Invalid Icpre value on type 6 |
                            Checks if I is defined for I, not equal to 14, 17, and 24. |
                            Lists all properties with icpre!=0 and isolid!= 14,17,24. |
                            Not supported. |
                                entity. |
                            | Negative Gap value on type 2 |
                            Checks if GAP is negative on Type 2 properties. |
                            Lists all properties of type 2 with a negative gap value. |
                            Not supported. |
                                entity. |
                            | Parameter and property title with & |
                            Checks if a property name has "&" when a parameter is defined
                                in the model. |
                            Lists all properties whose name has "&" when a parameter is
                            Not supported. |
                                entity. |
                            | Property with invalid name |
                            Checks if a property name has no more than 100 characters and
                            Lists all properties whose names are greater than 100 character,
                            Not supported. |
                                entity. |
                            | Prop and referenced entities not in same include |
                            Checks if a property and its curve, sensor, or system are in the
                                same include. |
                            Lists all properties which reference entities that are not in the
                                same include. |
                            Not supported. |
                                entity. |
                            | Istf is not equal to 0 or 1 for interface type 11 |
                            Checks if attribute Istf is not equal to zero or one for Inter
                                type 11. |
                            Lists all interfaces of type11 that have istf not equal to zero
                                or one. |
                            Not supported. |
                            Opens the interface card image of
                                    /INTER/TYPE11. |
                            | Idel is not equal to 1 for interface type 7 |
                            Checks if attribute Idel is not equal to one for interface type
                                7. |
                            Lists all interfaces of type7 that have Idel not equal to
                                one. |
                            Not supported. |
                                /INTER/TYPE7. |
                            | Bad Isearch flag interface in interface type 2 |
                            Checks if attribute Isearch is defined badly. |
                            Lists all interfaces of type2 that have Isearch not equal to zero
                                or two. |
                            Not supported. |
                            Opens the interface card image of /INTER/TYPE2. |
                            | Bad spotflag in interface type2 |
                            Checks if Spotflag is badly defined for interface type 2. |
                            Lists all interfaces of type2 that have a spotflag value not
                                equal to zero. |
                            Not supported. |
                                /INTER/TYPE2. |
                            | Slave nodes in multiple interfaces |
                            Checks if slave nodes are in multiple interfaces for
                                TYPE2. |
                            Lists all interfaces of type2 that have common slave nodes across
                                multiple interfaces. |
                            Not supported. |
                            Opens the Interface tool and updates the page. |
                            | Un-Tied nodes in interface type 2 |
                            Checks if there are any free nodes in tied contacts, that is,
                                contacts of type 2. |
                            Lists all type2 contacts with free nodes. |
                            Not supported. |
                            Not supported. |
                            | Groups and referenced entities not in same include |
                            Checks if group, master, slave, curves, and rbody are in the same
                                include. |
                            Lists all groups whose referenced entities are not in same
                                include files as the group. |
                            Not supported. |
                            Opens the Entity Editor of the group
                                entity. |
                            | Undefined master or slave in contact |
                            Checks if groups contain undefined master or slave
                                entities. |
                            Lists all groups that reference undefined master or slave
                                entities. |
                            Not supported. |
                                entity. |
                            | Unresolved master or slave in contact |
                            Checks if a contact contains unresolved entities. |
                            Lists all groups with unresolved master or slave
                                entities. |
                            Not supported. |
                                entity. |
                            | Parameter and group title with & |
                            Checks if a group name has "&" when a parameter is defined in
                                the model. |
                            Lists all groups whose names have "&" when a parameter is
                            Not supported. |
                                entity. |
                            | Group with invalid name |
                            Checks if a group name has no more than 100 characters and does
                            Lists all groups whose names are greater than 100 character or
                                begin with "/". |
                            Not supported. |
                                entity. |
                            | Free nodes in the model |
                            Checks if there are any free nodes in the model. Nodes present in
                                EREF are also not considered free by the solver. As they represent
                                the initial positions. |
                            Lists all of the free nodes in the model. |
                            Deletes free nodes. |
                            Not supported. |
                            | Incompatible kinematic conditions on nodes |
                            Checks if more than one type of imposed conditions is acting on
                                nodes; for example if nodes are connected to more than one of the
                                following - rigid elements, spotwelds, boundary conditions and tied
                                contacts. Based on skew, attached boundary condition directions are
                                checked if they are constrained in different dofs. |
                            Lists all of the nodes that have more than one imposed
                                condition. |
                            Not supported. |
                            Opens the Delete tool. |
                            | Free 1D element nodes |
                            Nodes at the free end(s) of 1D elements. |
                            List the free nodes of 1D elements |
                            NA |
                            Check the elements with free 1D and correct it. |
                            | Systems with axis badly defined |
                            Checks if the system axes are not defined correctly. |
                            Lists all of the Systs with axis that are badly defined. |
                            Not supported. |
                            Opens the Systs tool and updates the page. |
                            | Skew and nodes not in same include |
                            Checks if a system and its nodes are in the same include. |
                            Lists all of the systems that have nodes which are not in the
                                same include. |
                            Not supported. |
                            Opens the Entity Editor of the system
                                entity. |
                            | Parameter and system title with & |
                            Checks if a system name has "&" when a parameter is defined
                                in the model. |
                            Lists all systems whose names have "&" when a parameter is
                            Not supported. |
                                entity. |
                            | Systems with invalid name |
                            Checks if a system name has no more than 100 characters and does
                            Lists all systems whose names are greater than 100 character or
                                begin with "/". |
                            Not supported. |
                            Opens the EEntity Editor of the entity.
                            | Curve has no point |
                            Checks if the function curve has any points defined. |
                            Lists all of the function curves that do not have any points
                                defined. |
                            Creates a (0, 0) point. |
                            Opens the Curves tool and updates the page. |
                            | Parameter and curve title with & |
                            Checks if a curve name has "&" when a parameter is defined in
                                the model. |
                            Lists all curves whose names have "&" when a parameter is
                            Not supported. |
                                entity. |
                            | Curve with invalid name |
                            Checks if a curve name has no more than 100 characters and does
                            Lists all curves whose names are greater than 100 character or
                                begin with "/". |
                            Not supported. |
                                entity. |
                            | 1 slave node in Rbody |
                            Checks if there is only one slave node in a Rbody. |
                            Lists all of the Rbodies that have only 1 slave node. |
                            Not supported. |
                            Opens the Rigids tool and updates the page. |
                            | Admas and nodes not in same include |
                            Checks if Admas and nodes are in the same include. |
                            Lists all pf the admas that have nodes which are not in same
                                include. |
                            Not supported. |
                            Opens the Entity Editor of the mass
                                entity. |
                            | RBody and referenced entities not in same include |
                            Checks if RBody, nodes, skew, sensor, and surf are in the same
                                include. |
                            Lists all of the rbodies that reference entities which are not in
                                same include as the rbody. |
                            Not supported. |
                                Rbodies. |
                            | RLink and referenced entities not in same include |
                            Checks if Rlink, nodes, and skew are in the same include. |
                            Lists all pf the rlinks that have nodes or skew which are not in
                                same include. |
                            Not supported. |
                                Rlink. |
                            | Cyclic joint and nodes not in same include |
                            Checks if a cyclic joint and its nodes are in the same
                                include. |
                            Lists all of the cyclic joints that have nodes which are not in
                                same include. |
                            Not supported. |
                            Opens the EEntity Editor of the cyclic
                                joint. |
                            | Beam: 3 nodes aligned |
                            Checks that the 3 nodes of a beam are non collinear. |
                            Lists beams with 3 nodes that are collinear. |
                            Not supported. |
                            Opens the Bars tool. |
                            | Small rigid body with non-spherical inertia |
                            Checks if RBODY has non-spherical inertia. |
                            Lists all small Rbodies that have non-spherical inertia. |
                            Not supported. |
                            | Spring elements length greater than 35 |
                            Checks if a spring with a property of
                                    /PROP/SPR_PUL assigned to its component has a
                                length that is less than 35. |
                            Lists all spring elements with a length greater than 35. |
                            Delete the element. |
                            Not supported. |
                            | Rigid body connected to only one part |
                            Checks if rigid body slave nodes are connected to more than one
                                component. |
                            Lists all of the rigid bodies that are connected to only one
                                part. |
                            Not supported. |
                            | Rigid body has free slave nodes |
                            Checks if all dependent nodes of rigid bodies are connected to
                                some element. |
                            Lists all RBODY that have at least one free dependent
                                node. |
                            Removes the free end nodes from the rigid body. |
                            Not supported. |
                            | Free spring elements |
                            Checks if there are free spring elements |
                            Lists all of the free spring elements. |
                            Deletes free spring elements. |
                            Not supported. |
                            | Free bar2 elements |
                            Checks if there are free bar2 elements. |
                            Lists all the free bar2 elements. |
                            Deletes free bar2 elements. |
                            Not supported. |
                            | RBE3 has free independent nodes |
                            Checks for RBE3 elements which have independent nodes not
                                connected to any other elements. |
                            NA |
                            Free node in RBE3 will be removed. |
                            | Spring elems with null length |
                            Checks if spring elements have a null length. Excludes those
                                attached to properties of type 8. |
                            Lists all spring elements that have a null length, other than
                                those attached to properties of type 8. |
                            Delete the spring elements. |
                            Not supported. |
                            | Bar2 elems with null length |
                            Checks of bar2 elements have a null length. |
                            Lists all bar2 elements that have a null length. |
                            Deletes the bar2 elements. |
                            Not supported. |
                            | Mass elements have zero or negative mass |
                            Checks if there are any mass elements that have zero or negative
                                mass. |
                            Lists all mass elements that have zero or negative mass. |
                            Not supported. |
                            Opens the Admas tool and updates the page. |
                            | Admas not compatible with 2D analysis |
                            Checks if admas is present in the model, along with 2D
                                analysis. |
                            Lists all admas elements, if the 2D analysis flag is set. |
                            Not supported. |
                                entity. |
                            | Free mass elements |
                            Checks if there are free mass elements. |
                            Lists all of the free mass elements. |
                            Deletes free mass elements. |
                            Not supported. |
                            | Joint nodes are non-coincident |
                            Checks if a spring element that has a property of
                                    /PROP/KJOINT2 assigned to its component has a
                                node1 and node2 that are coincident. |
                            Lists all spring elements with non-coincident node 1 and node
                                2. |
                            Deletes the elements. |
                            Not supported. |
                            | 3-4 Node shells with thickness |
                            Checks if 3 or 4 noded shell elements have a thickness defined on
                                the element itself. |
                            Lists all 3 or 4 noded shell elements with a thickness. |
                            Not supported. |
                                entity. |
                            | Element connectivity |
                            Checks for shell elements connected by one or less nodes and
                                solid elements connected by two or less nodes. |
                            Lists the failing elements. |
                            Deletes the failing elements. |
                            Not supported. |
                            | Xalea of Random noise less than or equal to zero |
                            Checks for random noise. You will have a random noise issue if
                                the attribute XALEA of RANDOM control card is not equal to or less
                                than zero. |
                            Lists all the RANDOM control cards that have an attribute XALEA
                                not equal to or less than zero. |
                            Not supported. |
                            Opens the card image of control card
                                /RANDOM. |
                            | Unused boxes |
                            Checks if there are unused boxes in the model. |
                            Lists all unused boxes. |
                            Deletes unused boxes. |
                            Not supported. |
                            | Parameter and box title with & |
                            Checks if a box name has "&" when a parameter is defined in
                                the model. |
                            Lists all boxes whose names have "&" when a parameter is
                            Not supported. |
                                entity. |
                            | Boxes with invalid name |
                            Checks if a box name has no more than 100 characters and does not
                                begin with a "/". |
                            Lists all boxes whose names are greater than 100 character or
                                begin with "/". |
                            Not supported. |
                                entity. |
                            | Component is referring to undefined entity |
                            Checks if components reference undefined properties or
                                materials. |
                            Lists all components containing undefined materials or
                                properties. |
                            Not supported. |
                                entity. |
                            | Component is referring to unresolved entity |
                            Checks if components reference unresolved properties or
                                materials. |
                            Lists all components containing unresolved materials or
                                properties. |
                            Not supported. |
                                entity. |
                            | Hourglass possible on component |
                            Checks if hourglass is possible on a component; if the attached
                                property has ishell = 1,2 or 3 or isolid = 1 or 2. |
                            Lists all components with property attributes as mentioned
                                earlier. |
                            Not supported. |
                                entity. |
                            | Parameter and component title with & |
                            Checks if a component name has "&" when a parameter is
                            Lists all components whose names have "&" when a parameter is
                            Not supported. |
                                entity. |
                            | Comps with invalid name |
                            Checks if a component name has no more than 100 characters and
                            Lists all components whose names are greater than 100 character
                            Not supported. |
                                entity. |
                            | Part and referenced entities not in same include |
                            Checks if a part and its associated entities are in the same
                                include file. |
                            Lists all parts which reference entities that are not in the same
                                include file. |
                            Not supported. |
                                entity. |
                            | Unused sets |
                            Checks if a set is not referenced by another entity. |
                            Lists all sets which are unused. |
                            Deletes unused sets. |
                            Not supported. |
                            | Empty sets |
                            Checks if a set has entity ids. |
                            Lists all sets which do not contain any entities. |
                            Deletes empty sets. |
                            Not supported. |
                            | Sets with no finite elements or nodes |
                            Checks if the defined set contains valid finite elements/nodes.
                                This check does not report sets already reported under "empty
                                sets". |
                            Lists all sets which have empty components, sets, and so on
                                attached to them. |
                            Not supported. |
                                entity. |
                            | Grspri with inconsistent element |
                            Checks if Grspri contains only spring elements. |
                            Lists all Grspri that contain more than spring elements. |
                            Not supported. |
                            Not supported. |
                            | Grbeam with inconsistent element |
                            Checks if Grbream contains only beam elements. |
                            Lists all Grbream that contain more than spring elements. |
                            Not supported. |
                            Not supported. |
                            | Grshel with inconsistent element |
                            Checks if Grshel contains only 4 noded elements. |
                            Lists all Grshel that contain more than 4 noded shell
                                elements. |
                            Not supported. |
                            Not supported. |
                            | Grsh3n with inconsistent element |
                            Checks if Grsh3n contains only 3 noded shell elements. |
                            Lists all Grsh3n that contain more than 3 noded shell
                                elements. |
                            Not supported. |
                            Not supported. |
                            | Grtruss with inconsistent element |
                            Checks if Grtruss contains only truss elements. |
                            Lists all Grtruss that contain more than truss elements. |
                            Not supported. |
                            Not supported. |
                            | Grquad with inconsistent element |
                            Checks if Grquad contains only quad elements. |
                            Lists all Grquad that contain more than quad elements. |
                            Not supported. |
                            Not supported. |
                            | Grbric with inconsistent element |
                            Checks if Grbric contains only brick elements. |
                            Lists all Grbric that contain more than brick elements. |
                            Not supported. |
                            Not supported. |
                            | Entity set refers to undefined entity |
                            Checks if sets contain undefined entities. |
                            Lists all sets that reference undefined entities. |
                            Not supported. |
                            Opens the Entity Editor for the
                                entity. |
                            | Entity set is referring to unresolved entity |
                            Checks if a set contains unresolved entities. |
                            Lists all sets which refer to unresolved entities. |
                            Removes unresolved entities from the set. |
                            Not supported. |
                            | Parameter and set title with & |
                            Checks if a set name has "&" when a parameter is defined in
                                the model. |
                            Lists all sets whose names have "&" when a parameter is
                            Not supported. |
                                entity. |
                            | Sets with invalid name |
                            Checks if a set name is no more than 100 characters and does not
                                begin with "/". |
                            Lists all sets whose names are greater than 100 characters or
                                begin with "/". |
                            Not supported. |
                                entity. |
                            | Grbeam and referenced entity not in same include |
                            Checks if a Grbeam and its associated entities are in the same
                                Include file. |
                            Lists all Grbeams which reference entities that are not in the
                                same Include file. |
                            Not supported. |
                                entity. |
                            | Grbric and referenced entity not in same include |
                            Checks if a Grbric and its associated entities are in the same
                                Include file. |
                            Lists all Grbrics which reference entities that are not in the
                            Not supported. |
                                entity. |
                            | Grnod and referenced entity not in same include |
                            Checks if a Grnod and its associated entities are in the same
                                Include file. |
                            Lists all Grnods which reference entities that are not in the
                            Not supported. |
                                entity. |
                            | Grpart and referenced entity not in same include |
                            Checks if a Grpart and its associated entities are in the same
                                Include file. |
                            Lists all Grparts which reference entities that are not in the
                            Not supported. |
                                entity. |
                            | Grquad and referenced entity not in same include |
                            Checks if a Grquad and its associated entities are in the same
                                Include file. |
                            Lists all Grquads which reference entities that are not in the
                            Not supported. |
                                entity. |
                            | Grsh3n and referenced entity not in same include |
                            Checks if a Grsh3n and its associated entities are in the same
                                Include file. |
                            Lists all Grsh3ns which reference entities that are not in the
                            Not supported. |
                                entity. |
                            | Grshel and referenced entity not in same include |
                            Checks if a Grshel and its associated entities are in the same
                                Include file. |
                            Lists all Grshels which reference entities that are not in the
                            Not supported. |
                                entity. |
                            | Grspri and referenced entity not in same include |
                            Checks if a Grspri and its associated entities are in the same
                                Include file. |
                            Lists all Grspris which reference entities that are not in the
                            Not supported. |
                                entity. |
                            | Grtruss and referenced entity not in same include |
                            Checks if a Grtruss and its associated entities are in the same
                                Include file. |
                            Lists all Grtrusses which reference entities that are not in the
                            Not supported. |
                                entity. |
                            | Surf and referenced entity not in same include |
                            Checks if a Surf and its associated entities are in the same
                                Include file. |
                            Lists all Surfs which reference entities that are not in the same
                                Include file. |
                            Not supported. |
                                entity. |
                            | Bcs, grnod, skew not in same include |
                            Checks if Bcs, Grnod, and skew are in same include. |
                            Lists all bcs that have nodes or skew which are not in same
                                include. |
                            Not supported. |
                            Opens the Entity Editor of the load
                                collector entity. |
                            | Inivel, grnod and skew not in same include |
                            Checks if Inivel, Grnod and skew are in same include. |
                            Lists all inivel whose nodes or skew are not in same
                                include. |
                            Not supported. |
                                collector entity. |
                            | Impvel, and referenced entities not in same include |
                            Checks if impvel, grnod, sensor, skew and curves are in the same
                                include. |
                            Lists all impvel with nodes, sensor, skew, or curves that are not
                                in same include as itself. |
                            Not supported. |
                                collector entity. |
                            | Impdisp, and referenced entities not in same include |
                            Checks if impdisp, grnod, sensor, skew, and curves are in the
                                same include. |
                            Lists all impdisp with nodes, sensor, skew, or curves that are
                                not in same include as itself. |
                            Not supported. |
                                collector entity. |
                            | Pload, referenced entities not in same include |
                            Checks if Pload, Surf, sensor, Skew, and Curves are in the same
                                include. |
                            Lists all pload with surfs, sensor, contact surfs, skew, or
                                curves that are not in same include as itself. |
                            Not supported. |
                                collector entity. |
                            | Grav, and referenced entities not in same include |
                            Checks if Grav, Grnod, sensor, Skew, and curves are in the same
                                include. |
                            Lists all grav with nodes, sensor, skew, or curves that are not
                            Not supported. |
                                collector entity. |
                            | Parameter and loadcol title with & |
                            Checks if a load collector name has "&" when a parameter is
                            Lists all load collectors whose names have "&" when a
                                parameter is defined in the model. |
                            Not supported. |
                                entity. |
                            | Detpoint and referenced entities not in same include |
                            Checks if a Detpoint and its associated entities are in the same
                                Include file. |
                            Lists all Detpoints which reference entities that are not in the
                            Not supported. |
                                entity. |
                            | Activ and references entities not in same include |
                            Checks if an Activ and its associated entities are in the same
                                Include file. |
                            Lists all Activs which reference entities that are not in the
                            Not supported. |
                                entity. |
                            | Unresolved ids in Activ |
                            Checks if an Activ contains unresolved entities. |
                                unresolved. |
                            Not supported. |
                                entity. |
                            | Cload and referenced entities not in same include |
                            Checks if a Cload and its associated entities are in the same
                                Include file. |
                            Lists all Cloads which reference entities that are not in the
                            Not supported. |
                                entity. |
                            | Convec and referenced entities not in same include |
                            Checks if a Convec and its associated entities are in the same
                                Include file. |
                            Lists all Convec which reference entities that are not in the
                            Not supported. |
                                entity. |
                            | Impacc and referenced entities not in same include |
                            Checks if an Impacc and its associated entities are in the same
                                Include file. |
                            Lists all Impaccs which reference entities that are not in the
                            Not supported. |
                                entity. |
                            | Imptemp and referenced entities not in same include |
                            Checks if an Imptemp and its associated entities are in the same
                                Include file. |
                            Lists all Imptemps which reference entities that are not in the
                            Not supported. |
                                entity. |
                            | Pfluid and referenced entities not in same include |
                            Checks if a Pfluid and its associated entities are in the same
                                Include file. |
                            Lists all Pfluids which reference entities that are not in the
                            Not supported. |
                                entity. |
                            | Radiation and referenced entities not in same include |
                            Checks if a Radiation and its associated entities are in the same
                                Include file. |
                            Lists all Radiations which reference entities that are not in the
                            Not supported. |
                                entity. |
                            | Detline and referenced entities not in same include |
                            Checks if a Detline and its associated entities are in the same
                                Include file. |
                            Lists all Detlines which reference entities that are not in the
                            Not supported. |
                                entity. |
                            | Waveshapers and referenced entities not in same include |
                            Checks if a Waveshaper and its associated entities are in the
                            Lists all Waveshapers which reference entities that are not in
                                the same Include file. |
                            Not supported. |
                                entity. |
                            | Laser and referenced entities not in same include |
                            Checks if a Laser and its associated entities are in the same
                                Include file. |
                            Lists all Lasers which reference entities that are not in the
                            Not supported. |
                                entity. |
                            | Inout and referenced entities not in same include |
                            Checks if an Inout and its associated entities are in the same
                                Include file. |
                            Lists all Inouts which reference entities that are not in the
                            Not supported. |
                                entity. |
                            | Loadcols with Invalid name |
                            Checks if a load collector name is not more than 100 characters
                            Lists all load collectors whose names are greater than 100
                                characters or begin with "/". |
                            Not supported. |
                                entity. |
                            | Unused BeamSections  |
                            Checks if any beamsection defined in the model is unused. |
                            Lists all of the unused beamsections in the model. |
                            Deletes the unused beamsections. |
                            Not supported. |
                            | Unused parameters |
                            Checks if there are any unused parameters in the model. |
                            Lists all parameters that are unused/not referenced in another
                                entity. |
                            Deletes unused parameters. |
                            Not supported. |
                            | Parameter definition in include file |
                            Checks if parameters are present in include files. If yes, then
                                give a warning. PARAMETER/LOCAL is currently not supported, hence
                                the check. |
                            Lists all parameters that are defined in the include
                                file. |
                            Not supported. |
                            Opens the Entity Editor of the parameter
                                entity. |
                            | Fcut is greater than or equal to 0 for Accel |
                            Checks if Fcut is greater than zero on an Accel card. |
                            Lists all Accels with Fcut less than or equal to zero. |
                            Not supported. |
                                entity. |
                            | More than one Accel on the same node |
                            Checks if more than one Accel is acting on the node. |
                            Lists all Accels repeated on the node. |
                            Not supported. |
                                entity. |
                            | Accel and referenced entities not in same include |
                            Checks if an Accel and its referenced entities are in the same
                                Include file. |
                            Lists all Accels which reference entities that are not in the
                            Not supported. |
                                entity. |
                            | Node id and skew id for accel card are unresolved |
                            Checks if node_id and skew_id are unresolved for the accel
                                card. |
                            Lists all Accels with an unresolved node_id or skew_id. |
                            Not supported. |
                                entity. |
                            | Nodes with same skew in different TH |
                            Checks if the same node with the same system is referenced in
                                more than one TH. |
                            Lists all output blocks that contain a node that is repeated with
                                the same system. |
                            Not supported. |
                                entity. |
                            | TH with repeated entities |
                            Checks if entities are repeated within each TH. |
                            Lists all output blocks that contain repeated node IDs. |
                            Not supported. |
                                entity. |
                            | Parameter and output block title with & |
                            Checks if an output block name has "&" when a parameter is
                            Lists all output blocks whose names have "&" when a parameter
                            Not supported. |
                                entity. |
                            | Output blocks with invalid name |
                            Check if an output block name is no more than 100 characters and
                                does not begin with "/". |
                            Lists all output blocks whose names are greater than 100
                            Not supported. |
                                entity. |
                            | Th and referenced entities not in same include |
                            Checks if Th and its associated entities are in the same Include
                                file. |
                            Lists all Th which reference entities that are not in the same
                                Include file. |
                            Not supported. |
                                entity. |
                            | Parameter and contact surf title with & |
                            Checks if a contact surface name has "&" when a parameter is
                            Lists all contact surfaces whose names have "&" when a
                            Not supported. |
                                entity. |
                            | Contact surfs with invalid name |
                            Checks if a contact surface name is not more than 100 characters
                                and does not begin with "/". |
                            Lists all contact surfaces with names greater than 100 characters
                                or begins with "/". |
                            Not supported. |
                                entity. |
                            | Monvol, surfs, sensors, curves not in same include |
                            Checks if a control volume and its associated surface, sensor, or
                                curve are in the same Include file. |
                            Lists all control volumes which reference entities that are not
                            Not supported. |
                                entity. |
                            | Control vols with invalid name |
                            Checks if a control volume name is not more than 100 characters
                            Lists all control volumes with names greater than 100 characters
                            Not supported. |
                                entity. |
                            | Parameter and control vol title with & |
                            Checks if a control volume name has "&" when a parameter is
                            Lists all control volumes whose names have "&" when a
                            Not supported. |
                                entity. |
                            | Incompatible material |
                            Checks if materials and properties are compatible with xref and
                                refsta. |
                            Lists all xref/refsta with incompatible materials or
                                properties. |
                            Not supported. |
                                entity. |
                            | Eref incompatible material |
                                Eref. |
                            Lists all Eref with incompatible materials or properties. |
                            Not supported. |
                                entity. |
                            | XRef or Refsta, and nodes not in same include |
                            Checks if Xref/Refsta and its nodes are in the same
                                include. |
                            Lists all impdisp with nodes, skew, or curves that are not in the
                            Not supported. |
                            Opens the Entity Editor of the control
                                volume entity. |
                            | Airbag1 and referenced entities not in same include |
                            Checks if an Airbag1 and its associated entities are in the same
                                Include file. |
                            Lists all Airbag1s which reference entities that are not in the
                            Not supported. |
                                entity. |
                            | Area and referenced entities not in same include |
                            Checks if an Area and its associated entities are in the same
                                Include file. |
                            Lists all Areas which reference entities that are not in the same
                                Include file. |
                            Not supported. |
                                entity. |
                            | Commu1 and referenced entities not in same include |
                            Checks if a Commu1 and its associated entities are in the same
                                Include file. |
                            Lists all Commu1s which reference entities that are not in the
                            Not supported. |
                                entity. |
                            | Fvmbag1 and referenced entities not in same include |
                            Checks if a Fvmbag1 and its associated entities are in the same
                                Include file. |
                            Lists all Fvmbag1s which reference entities that are not in the
                            Not supported. |
                                entity. |
                            | Pres and referenced entities not in same include |
                            Checks if a Pres and its associated entities are in the same
                                Include file. |
                            Lists all Pres which reference entities that are not in the same
                                Include file. |
                            Not supported. |
                                entity. |
                            | Perfect gas and referenced entities not in same include |
                            Checks if an Perfect gas and its associated entities are in the
                            Lists all Perfect gases which reference entities that are not in
                            Not supported. |
                                entity. |
                            | Airbag and referenced entities not in same include |
                            Checks if an Airbag and its associated entities are in the same
                                Include file. |
                            Lists all Airbags which reference entities that are not in the
                            Not supported. |
                                entity. |
                            | Commu and referenced entities not in same include |
                            Checks if a Commu and its associated entities are in the same
                                Include file. |
                            Lists all Commus which reference entities that are not in the
                            Not supported. |
                            Opens the Entity Editorfor the
                                entity. |
                            | Fvmbag and referenced entities not in same include |
                            Checks if a Fvmbag and its associated entities are in the same
                                Include file. |
                            Lists all Fvmbags which reference entities that are not in the
                            Not supported. |
                                entity. |
                            | Sections, N1, N2, N3 not in same include |
                            Checks if a Cross Section and its associated nodes are in the
                            Lists all Cross sections which reference nodes that are not in
                            Not supported. |
                                entity. |
                            | Sections, sets and frames not in same include |
                            Checks if a Cross section and its associated sets and frames are
                            Lists all Cross sections which reference sets and frames that are
                                not in the same Include file. |
                            Not supported. |
                                entity. |
                            | Parameter and cross section title with & |
                            Checks if a cross section name has "&" when a parameter is
                            Lists all cross sections whose names have "&" when a
                            Not supported. |
                                entity. |
                            | Cross sections with invalid name |
                            Checks if a cross section name has no more than 100 characters
                                and does begin with "/". |
                            Lists all cross sections whose names are greater than 100
                            Not supported. |
                                entity. |
                            | Prop17 Incompatible with /INISHE_ORTHO_LOC or
                                    /INISH3_ORTHO_LOC |
                            Lists all properties linked to elements referenced by
                                    /INISHE/ORTHO_LOC or
                                    /INISH3/ORTHO_LOC tables. |
                            Not supported. |
                            Opens the Entity Editor for the property
                                entity. |
                            | Incompatible materials within SUBMODEL block |
                            | Elementcluster referring to undefined sets |
                            | Incompatible properties within SUBMODEL block |
                            | Unused transformations |
                            | Plies with in-consistent def_ortho  |
                            | Empty positions |
                            | Is there a common node among DAMPING |
