| Unused materials |
                            Checks for materials that are not referenced by a
                                component. |
                            Lists all unused materials. |
                            Deletes unused materials. |
                            Not supported. |
                            | Unused properties |
                            Check for properties that are not used in the model. |
                            Lists all unused properties. |
                            Deletes unused properties. |
                            Not supported. |
                            | Property is missing a card image |
                            Checks for properties that do not have a card image. |
                            List all properties that do not have card images. |
                            Not supported. |
                            Opens the Property Create tool. |
                            | Property missing mass value |
                            Checks if mass properties that do not have element mass
                                defined. |
                            Lists all Mass properties that do not have mass assigned. |
                            Not supported. |
                            Opens the Property tool. |
                            | Damper property is missing Damping and Mass value |
                            Checks if Damper properties are missing the Damping or Mass
                                value. |
                            Lists all Damper properties that do not have damping/mass
                                assigned. |
                            Not supported. |
                            | Beam Property missing HyperBeam Section |
                            Checks if Beam properties are missing HyperBeam sections. |
                            Lists all Beam properties that do not have beam section
                                properties assigned. |
                            Not supported. |
                            | Empty Components |
                            Checks if components have one or more elements. |
                            Lists all components that do not have elements. |
                            Deletes empty components. |
                            Not supported. |
                            | Unsed Sets |
                            Check if sets are not used in the model. |
                            Lists all unused sets. |
                            Deletes empty sets. |
                            Not supported. |
                            | Empty sets |
                            Check if sets are empty. |
                            List empty sets. |
                            Not supported. |
                            | Empty groups |
                            Checks if groups have either a master entity or slave entity that
                                are assigned a contact surface/set. |
                            Lists all groups with missing master and slave entities. |
                            Deletes empty groups. |
                            Not supported. |
                            | Empty contactsurfs |
                            Checks if contactsurfs are assigned any elements. |
                            Lists all empty contactsurfs. |
                            Deletes empty contactsurfs. |
                            Not supported. |
                            | Unused Sections |
                            Check if there are any unused Beamsections defined in the
                                model. |
                            List all unused Beamsection collectors in the model. |
                            Deletes unused beamsections. |
                            Not supported. |
                            | Empty loadcollectors |
                            Checks if there are any loads in the load collectors. |
                            Lists all loadcollectors that do not have loads. |
                            Deletes empty loadcollectors. |
                            Not supported. |
                            | Empty Vectorcollectors |
                            Checks if there are any empty vector collectors. |
                            Lists all empty vectors. |
                            Deletes empty vectors. |
                            Not supported. |
                            | Empty assemblies |
                            Checks if there are any empty assemblies. |
                            Lists all empty assemblies. |
                            Deletes empty assemblies. |
                            Not supported. |
                            | BeamSection with invalid name (> 40 characters) |
                            Checks if there are any beam section name string has more than 40
                                characters |
                            Lists all the Beam Sections name string with > 40 characters  |
                            Not supported |
                            Editing of Beam section names to < 40 characters |
                            | VectorCollector with invalid name (> 40 characters) |
                            Checks if there are any Vector name string has more than 40
                                characters |
                            Lists all the vectors name string with > 40 characters  |
                            Not supported |
                            | Assembly with invalid name (> 40 characters)v |
                            Checks if there are any Assembly name string has more than 40
                                characters |
                            Lists all the Assembly name string with > 40 characters |
                            Not supported |
                            Editing of Assembly name string with < 40 characters |
                            | Material with invalid name (> 40 characters) |
                            Checks if there are any Material name string has more than 40
                                characters |
                            Lists all the Material name string with > 40 characters |
                            Not supported |
                            Editing of Material name string with < 40 characters |
                            | Property with invalid name (> 40 characters) |
                            Checks if there are any Property name string has more than 40
                                characters |
                            Lists all the Property name string with > 40 characters  |
                            Not supported |
                            Editing of Property name string with < 40 characters  |
                            | Component with invalid name (> 40 characters) |
                            Checks if there are any Component name string has more than 40
                                characters |
                            Lists all the Component name string with > 40 characters  |
                            Not supported |
                            Editing of Component name string with < 40 characters  |
                            | Set with invalid name (> 40 characters) |
                            Checks if there are any Set name string has more than 40
                                characters |
                            Lists all the Set name string with > 40 characters |
                            Not supported |
                            Editing of Set name string with < 40 characters |
                            | Group with invalid name (> 40 characters) |
                            Checks if there are any Group name string has more than 40
                                characters |
                            Lists all the Group name string with > 40 characters |
                            Not supported |
                            Editing of Group name string with < 40 characters |
                            | Contactsurf with invalid name (> 40 characters) |
                            Checks if there are any Contactsurf name string has more than 40
                                characters |
                            Lists all the Contactsurf name string with > 40 characters  |
                            Not supported |
                            Editing of Contactsurf name string with < 40 characters
                            | LoadCollector with invalid name (> 40 characters) |
                            Checks if there are any Load collector name string has more than
                                40 characters |
                            Lists all the Load collector name string with > 40
                                characters |
                            Not supported |
                            Editing of Load collector name string with < 40
                                characters |
                            | SystemCollector with invalid name (> 40 characters) |
                            Checks if there are any System Collector name string has more
                                than 40 characters |
                            Lists all the System name string with > 40 characters |
                            Not supported |
                            Editing of System name string with < 40 characters |
                            | Element connectivity |
                            Checks for shell elements connected by one or less nodes and
                                solid elements connected by two or less nodes. |
                            Lists the failing elements. |
                            NA |
                            Not supported. |
