Organize new and existing checks inside of a user-defined Check Folder.
            By default, checks are organized into the ERROR, WARNING, and INFO. You can create
                your own folder to organize checks in using the Check Folder entity.
                        - ERROR
                        - Checks with ERROR check-level, identifying modeling issues that need to
                            be fixed to ensure the model to be run by the solver.
                        - WARNING
                        - Checks with WARNING check-level, identifying modeling recommendations or
                            solver warnings to improve the quality of the model, but are not
                            critical for the model to be run by the solver.
                        - INFO
                        - Generic information on the content of the model.
                In the Model Checker, right-click and select Create
                        Folder from the context menu.
A new Check Folder is created, and opens in the Entity Editor.
                In the Name field, enter a folder name.
                Organize checks inside the newly created Check Folder.
                    - Create new checks directly in this folder by right-clicking on the
                        folder and selecting Create Check from the context menu.
                    - Move existing checks by dragging-and-dropping selected checks into the
                        folder.
