Table of Reference
Add a table of reference to the report.
- Right-click Report and select .
Or
From the Report ribbon, click the arrow next to the Add Item, then select Table of Reference.
Note: Report allows you to add only one Table of Reference for the session. - Once Table of Reference is added, a chapter titled Table of Reference is added to the tree. Also, a table entity titled Table of Reference is added under it.
 - Below are the properties associated with the Table entity.
Figure 1.- Name
 - Edit the name property of the reference table entity.
- Caption
 - Provide a caption for the table entity. This caption is visible in the exported Document report.
- Source
 - Select the data input type for the table entity. Available options
                                    are:
- Data
 - External CSV/XLSX
 - TableView Window
 - HyperMesh Table
 - Matrix Browser Table
- Advanced
- Location of Caption
 - Select the caption location from the list. These are
                                            standard locations as present in Microsoft Word. Table
                                            caption locations can be:
Figure 2. - Auto Split Table
 - Provides the function to split up tables automatically based on the space available in the slide or page.
 - To add a reference, select the required text and right-click Insert Table
                        of Reference.
A table of reference option is displayed. Select the required cell from the table and click OK. This adds a reference for the selected text item to the cell item in the table.
 - To add a cross reference, select the required text and right-click Add
                        Cross Reference.
A Select Item to Cross Reference dialog opens. You can select the required entity from the table and click OK.
