Table
Add a table to the report.
- Right-click at the Report or Chapter level and select
Or
From the Report Ribbon, Add Item tool group, click Table.Figure 1.
. - Below are the properties associated with the Table entity.Figure 2.
- Name
- You change the name property of the table item.
- Caption
- Provide a caption for the table entity. This caption is visible in the exported Document report.
- Source
- Select the data input type for the table entity. Available options
are:Figure 3.
- Data
- Edit data to the table entity. Data entry to the table
can be done through two methods.Figure 4.
- Manual: Enter the required number of rows and
columns and click Update.
This adds the number of rows and columns where you
can enter the data manually.Figure 5.
- Import: You can also import table data from a
CSV or XLSX file.
- Click Import. A file browser option is displayed.
- Select a file and click OK. This imports the data from the file and populates it in the table entity.
- External CSV/XLSX
- Import data from a CSV or an XLSX file. Select the
required file and define the cell range to be imported
to the table entity.Figure 6.
- TableView Window
- Import data to the table entity from the TableView
window in the session. Select the TableView page/window
for Location, define the cell range and other advanced
options.Figure 7.
- HyperMesh Table
- Import data to the table entity from an existing
HyperMesh Table
collector in the session. Select the HyperMesh page/window for
Location and select the required table from the Table
list.Figure 8.
- Matrix Browser Table
- Use Matrix Browser table and
Matrix Browser Macro script to
generate data for the table entity.Figure 9.
- Advanced
- Location of Caption
- Select the caption location from the list. These are
standard locations as present in Microsoft Word. Table
caption locations can be:Figure 10.
- Auto Split Table
- Provides the function to split up tables automatically based on the space available in the slide or page.
- By
- Select if you want to split the table along the columns or rows.
- Maximum Rows
- Enter the value for the maximum number of rows for the table.
- Maximum Columns
- Enter the value for the maximum number of columns for the table.
